offroad lights help
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Apr 30, 2010.
  1. Apr 30, 2010 at 9:41 AM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    hey guys i have 2 100watt light on my light bar....but the fuse keeps blowing out... everything is connected the right way....can it be the fuse the fuse i have on it now is a 25 fuse....can i put a 30 fuse in there?????
  2. Apr 30, 2010 at 9:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    putting in a bigger fuse wont help...it'll keep blowing the fuse or melt the wiring harness. recheck all your connections....all your grounds and make sure something isnt crossed up.
  3. Apr 30, 2010 at 10:08 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Get a relay
  4. Apr 30, 2010 at 5:03 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    200 watts is a lot of juice to run through the switch (if you don't have a relay).
    When I switched from the pair of 35 watt Kragen HIDs (70 total) to a pair of 100 watt Hella 4000 Halogens (200 total), I had to go with a relay, as well... It came with the Halogens' wire harness and switch (Hella).
  5. Apr 30, 2010 at 5:08 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I'd even go 40 or 50 Amp.
    You can buy them at Radio Shack for like 6 bucks. Look in the stereo section if there isn't a rack of car electronics.
  6. Apr 30, 2010 at 5:14 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    X2
  7. May 2, 2010 at 8:52 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    what gauge wire are you running? this will effect the power needs as well I have 2x55w and I have a 15 amp fuse so 25amp seems to be right but if its a long wire run and small gauge wire that could be the issue
  8. May 2, 2010 at 9:41 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Not likely. Running too small of a wire will result in the wire burning through. If you're blowing the fuse as soon as you try to turn on the lights, more than likely you've got a short (power wire touching ground somewhere). Definately hope you are using relays.
  9. May 2, 2010 at 9:53 AM
    Sheepdog
    Sheepdog Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    I have 4 100W lights on one switch and running only a 30 amp fuse and i dont have any problems with poping it. the lights all have 14awg wire for the hot and the groung and then I'm running 10awg from the battery to the switch and then 10 from the switch to the lights. Wire doesn't get hot or anything after having the lights on for a long time...
  10. May 2, 2010 at 10:22 AM
    xsvtoyz
    AL
    Oklahoma
    you are correct I'm sorry yes I am running a relay but thanks for askin :)
  11. May 2, 2010 at 10:44 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Two 100 watt lights only pull 17 amps. I have always used a 20 amp fuse to run two 100 watt lights. Never have blown a fuse.
    Did you use wire loom or tape to cover your wires? It does not take much of a sharp edge to rub through your wiring and cause a short to ground.
  12. May 2, 2010 at 10:47 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Didn't read the entire thread but you need a relay.
  13. May 2, 2010 at 3:07 PM
    David K
    My wire harness has a 30 amp fuse in it.
