offroad truck with trailer 4k
Discussion in 'Buy / Sell / Trade - Canada' started by Windigo, May 10, 2023.
  1. May 10, 2023 at 8:23 AM
    Windigo
    Windigo [OP] Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    balljoint likes this.
  2. May 10, 2023 at 9:59 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    trailer
    [/QUOTE]
    95 runner has seen mostly all trails in and around ontario so body shows it.
    22re with a psc power steering pump (some high output one)
    york air compressor mounted on engine and i think it still has the air tank mounted underneeth
    the stock fuel tank has been moved to the rear under truck
    w56 trans and trailgear dual t case down east offroad triple stick shifters
    dana 60 538 gears from 1st gen dodge diesel truck. ( the tie rod is mounted higher than other dana 60's from factory)
    pass. side pumpkin,
    yukon locker and i have the hydro assist somewhere just have to dig it up. the power steering box was taped for hydro assist.
    14 bolt 538 gears rear with a full case detroit locker disc brakes (some kit from barnes offroad)
    chevy 63 leafs rear and yj leafs front
    the truck has been sitting for a while and will need some tlc
    I'll get some pics and add them hear tomarrow. I'd like to post up the current condition not what it looked like in the past.
    thank you.
    comes with tandem axle car trailer with good tires and 1 axle has electric brake
  3. May 10, 2023 at 10:00 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Figured I’d add up the info and pics from the other thread for ya!
    super tempting….
  4. May 10, 2023 at 12:42 PM
    Windigo
    Farook
    '14 Acess Cab
    Thank you so much very much appreciated
    All the lights on the trailer work the electric brakes work and all the tires are good. I took the whole thing for a little drive today just to make sure
  5. Jun 12, 2023 at 2:57 PM
    CaygeonRunner
    CaygeonRunner Well-Known Member
    Brad
    4runner SR5
    Dobinson 302/325, Dobinson MRR F/R, 1/4" tophat, JBA UCA's, aluminum skids, custom sliders, Warn Evo 8, spidertrax, 33' Toyo MT's...
    Does it run?
    tacoma16 likes this.
  6. Jun 12, 2023 at 3:48 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m sure you could figure it out if it didn’t :)
  7. Jun 12, 2023 at 3:53 PM
    Windigo
    Farook
    '14 Acess Cab
    I haven't posted anything else up after I put the ad because I haven't had the time to go and get it running. Far as I know it probably just needs some fresh fuel and a battery but I'll see. The person who is storing it for me wants the trailer so that's kind of gone I can't say no to him.
  8. Jun 12, 2023 at 5:57 PM
    Windigo
    Farook
    '14 Acess Cab
    Calling everyone running 35/ 37s. What wheel bearings do you run. Just curious
  9. Jun 13, 2023 at 4:04 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    EBay specials. Can get a pair for $400 to the door if I recall that are made with the good bearings and things toyota uses. Evgeny has been using them and k believe Brad is too
    see if this link works:
    https://www.ebay.ca/itm/203154745621
    Windigo[QUOTED][OP] likes this.
