Offroad with the 6Speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mariotaco, Jul 16, 2015.
  1. Jul 16, 2015 at 10:29 AM
    Mariotaco
    Mariotaco [OP] Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    Any tips on how to shift with 6speed while offroading?
  2. Jul 16, 2015 at 12:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    4LO is gonna be your friend in technical stuff as to not burn up your clutch.
    There is a reason why i bought an auto... unless i was doing high speed stuff in the dunes where i want to hold a gear or something like that.... the auto is soooo much easier to drive in technical stuff.
    Manwithoutaplan likes this.
  3. Jul 16, 2015 at 12:56 PM
    Manwithoutaplan
    ID
    Your clutch button is your friend when on a steep hill.
    like nd4spdbh said most steep stuff and difficult situation 4lo is your friend. IF you have locker it will make alot easier to.
  4. Jul 16, 2015 at 3:53 PM
    nd4spdbh
    SoCal
    yeah clutch cancel start. Put her in 1st gear and 4lo with clutch out n start her up, you wont have to touch the clutch which will make it so you dont burn it up.
  5. Jul 17, 2015 at 12:06 PM
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    I am still not sure what the function of the clutch cancel start is design form. Is it just to start the truck without pressing the clutch?
  6. Jul 17, 2015 at 12:08 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    So if you stall on a hill you start it without putting the clutch in? Sounds sketchy
  7. Jul 17, 2015 at 1:12 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Run it in 4L and shift as needed and don't ride the clutch. If you cannot shift without losing all your forward speed stay in the lower gear. Unless you are into rock climbing and or serious off roading you will be fine.
    Most use it just to use it but it is seldom really needed. Unless you keep stalling the vehicle and are riding the clutch to start it moving again it is not needed.
  8. Jul 17, 2015 at 1:34 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I bought a 6 spd specifically for off roading. I prefer manual. 99% of the time I'm in 4lo, 2nd gear. I use 1st when descending rocks, maybe 3rd on a straight stretch. I don't use the clutch too much at all off road actually.
    Harry likes this.
  9. Jul 17, 2015 at 1:40 PM
    Spixelz
    Spixelz Well-Known Member
    Jesse
    Forest Grove, Oregon
    2015 White 6spd DCSB OR
    Icon Stage 4 w/Dakar Leafs
    I learned to wheel in a stick...Lets just say that rig smelled like clutch for a week! Someone then gave me a very simple tip and my vehicles since have thanked me!
    Just wheel in 4LO! Set it and forget it! Well don't forget it...
  10. Jul 17, 2015 at 1:50 PM
    Pigpen
    Dan
    Northwest Montana
    This
  11. Jul 17, 2015 at 1:51 PM
    Ianp05
    Ianp05 Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
  12. Jul 17, 2015 at 2:04 PM
    nd4spdbh
    SoCal
    exactly it. Not scketchy at all, allows you to get over an obstacle with finesse if you stalled and cant roll back.
    My old jeep didnt even have a clutch switch and this "feature" came in handy ALL the time.
  13. Jul 17, 2015 at 2:06 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Yes This.
    Clutch switch lock-out is great when you stall on a hill. People are afraid to use it thinking it will burn up the starter - it won't.
  14. Jul 17, 2015 at 2:13 PM
    Pigpen
    Dan
    Northwest Montana
    I've used it a few times (always 4lo 1st gear) - the truck was made to do this - great feature.
  15. Jul 17, 2015 at 2:50 PM
    anthony250f
    Anthony
    San Diego, CA
    Won't it just stall if you're in gear and do that
  16. Jul 17, 2015 at 3:25 PM
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    Thank you for the tips!!! I use it when I need to start my truck I don't want to hop in to start the clutch lol...The first time I used 4Lo was in the sand dunes I thought I was stuck but the 4lo saved my life but it was scary because it got stuck in 4Lo and could not get in 4x2 or 4hi.
  17. Jul 17, 2015 at 3:38 PM
    skootx
    Erie, CO
    That happens sometimes. Usually it's just a matter of driving forward a bit, then it will engage (or disengage). Sometimes you have to back up just a bit, then drive forward.
  18. Jul 17, 2015 at 4:25 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Like everyone has stated 4lo is you friend. Personally I have a tenancy to leave it in 4lo 1st when dealing with rocks and peddle the throttle to keep it from stalling. Just get out there with some experienced guys if you know any or join an off road club or association usually a wealth of knowledge there too best advice I can give
  19. Jul 17, 2015 at 5:47 PM
    nd4spdbh
    SoCal
    naw, just giver a lil gas.
  20. Jul 18, 2015 at 6:03 PM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    I don't do any hard core wheeling, but when i've gone up trails I used to hit in an auto I was really surprised how easy it is to use the 6spd manual Good tips are definitely using 4LO when warranted, keeps speed nice and controlled.
    Even in 4HI, you can let the RPMs get pretty low without any issues so don't worry about using the clutch when the RPMs drop but hold just below 1000 RPM.
    Smile at the guys driving autos as you pass, let them know you're more bad ass!
    :p
    Noahs2015Taco likes this.
