Offroading in non-Prerunner 4x2
Discussion in '4 Cylinder' started by Vrbas, Nov 30, 2010.
  1. Nov 30, 2010 at 9:32 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    Hey all, i'm not new to the forums but i'm new to my new truck (2011 5-speed access cab). I would have liked to have a 4x4 but money would not permit. I just started graduate school and this was my undergrad gift. I wanted something with "utility" that could drive off the beaten path every now and then (go places that cars couldn't go and stuff) but i wasn't interested in making it a trail monster with a hick-lift (don't want to offend others, we just got some really redneck people in Auburn). It will be seeing 90% street and maybe 10% off.
    Anyways, I want to leave it as stock as possible to maintain my fuel economy. I guess what i'm asking is how well my stock Tacoma would be able to handle offroad situations. I know i'm not going to be river diving or anything, but maybe some trails or muddy conditions. AND how might i improve it's effectiveness offroad without breaking bank or straying too far from factory look? Thanks again for all your help.
  2. Nov 30, 2010 at 9:40 PM
    SD2011Taco
    SD2011Taco Well-Known Member
    San Diego
    2011 SR5V6 4x4 Grey TRD Offroad Overland Setup
    3" Lift, Lights, CB, Yellow-Top, CBI Bed Rack, Tepui RTT, Shovel/Axe Mount, Maxtrax, ARB OBA, 33" KO2, Sliders
    It will handle fine. You may want to get better tires eventually.
  3. Nov 30, 2010 at 9:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    a traction device, such as a locker or limited slip differential. Or just a more aggressive tire like an all terrian. Both will make your truck more capable offroad.
  4. Nov 30, 2010 at 9:43 PM
    2009 taco
    2009 taco Well-Known Member
    juan
    lompton, CA
    09 sport
    jba headers, outlaw flowmaster, 3 inch pipes, k and n cold air intake, throttle body spacer, halo headlights, HIDs, deaver springs, kings all the way round, Built right UCAs, camburg spindles, Satoshi bumper and main grill, sliders
    Yeah you should be fine better tires, air down, and dont go alone. stick to those and you will be ok:cool:
    Plain Jane Taco and DustStorm4x4 like this.
  5. Nov 30, 2010 at 9:47 PM
    Vrbas
    is an LSD or locker gonna be expensive? What piece of equipment is it exactly?
  6. Nov 30, 2010 at 9:52 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Sandbags over the rear axle to add weight (and grip) for the drive tires.
  7. Nov 30, 2010 at 9:56 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    go with a locker. LSD sucks offroad
  8. Nov 30, 2010 at 10:02 PM
    ktmrider
    Junk
    Yeah they are expensive, and a locker would be much better offroad. It causes the rear differential to be "locked together" and instead of having the power transfered to the tire with the least resistance, it will give it equally to both and give you better traction.
  9. Nov 30, 2010 at 10:14 PM
    Vrbas
    Like 1-2k expensive?
    Thanks for all the input guys
  10. Nov 30, 2010 at 10:24 PM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    I'm suprised your 2011 didn't already come with a LSD. My 2010 5 Lug Taco came with one, I just thought it was standard. I got to try mine out this last weekend in some soupy grass/mud mix while camping down in Kentucky. It did ok I guess...I didn't get stuck and I could hear it engaging.
    Withoug breaking the bank, I am going to suggest the same things I plan on doing. Slightly bigger tires(mostly for look) 235/75/R15 these really fill in the wheel wells and add a little more on road stability. Get something more than just a street tire, good all terrain would be great. A set of Firestone Destination A/T's should be well under $500. 235's fit on the stock rim no problem, don't require lift, and don't suck so much power you feel the need to regear and they just look better, IMO.
    Next is adding some weight when you go off road, sand bags over the axle work pretty good. And just remember you are in a 2wd, don't ask more from your truck than it can handle. Always 2nd guess your path, don't get so far in, you can't get back out.
  11. Nov 30, 2010 at 10:29 PM
    Vrbas
    It came w/ "auto LSD" or something, there's a button for it i can switch on and off (I believe it's on by normal unless i switch it off). Is it the same thing as the mechanical one?
  12. Dec 1, 2010 at 12:32 AM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    definitley get all terrains! I recently went from a 99 mazda b2500 to my 97 t100 and the t100 has BFG long trails and i was very impressed the first time i took it off road
    although it could be that the T has 4:10 gears and a 3.4l v6 190 hp and weighs less than the maz did, and the mazda had 3:73s with a 2.5l 4cyl with 119 hp of pavement pounding fury ... but the t crawled right up that stuff and its 2wd too!
  13. Dec 1, 2010 at 6:55 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    By saying non-prerunner 4x2, means you have a 5lugger. I would suggest a Fat Bob's Garage lift or Readylift to lift the truck and gain some ground clearance as well as getting bigger tires 31x10.5x15's are ideal... Of course locker will make crawling much easier, inexpensive and easy to install is the Powertrax no-slip locker...
  14. Dec 1, 2010 at 8:53 AM
    Vrbas
    I appreciate the input, but i'm not interested. I'm trying to keep the puppy looking stock or close to so a lift and 30inch tires are out of the question for me. I know people will say "Well if you won't lift it or put bigger tires on it, you won't be able to do anything" blah blah. That's why I'm asking IF there's anything i can do to maintain factory profile while still improving my abilities offroad.
    Sorry if that came across in an offensive tone, i didn't mean it to be :eek:
  15. Dec 1, 2010 at 8:55 AM
    05RedTaco
    Tony
    Scottsdale
    Gotta keep in mind that stock the 5lugger has very low ground clearance. Yes you can do dirt roads, or gravel roads... However I wouldn't attempt any rock crawling with stock height...
    DustStorm4x4 likes this.
  16. Dec 1, 2010 at 8:56 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I would just run a nice set of 235 tires. Gives you increased traction, there's no need to lift, and it actually corrects the factory error in the speedo. Otherwise, you still have more ground clearance than a car, so it should easily be able to handle simple off road tasks.
  17. Dec 1, 2010 at 9:02 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if you dont want better/bigger tires then I wouldnt try anything other than gravel roads. those trucks have low ground clearance and are not built for off roading in the stock form.
  18. Dec 1, 2010 at 9:05 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I's say after install and parts it'd be between 700 to 1000. Depending on which company you went with. I'd get ARB with on board air
  19. Dec 1, 2010 at 9:06 AM
    Vrbas
    I don't plan on rock crawling really, maybe some woodsy trails with fallen branches and stuff, would i be alright for that? Also, isn't my ground clearance still above average? I know the 5luggers sit lower than 4x4 and prerunners but is clearance really an "issue"?
  20. Dec 1, 2010 at 9:23 AM
    05RedTaco
    Tony
    Scottsdale
    If you don't want a lift at least get some 235/70/15 A/T tires... The stock tires are crap. Less crap on road, more crap off road...
