Offset Help
Discussion in 'Wheels & Tires' started by Taco813, Oct 14, 2018.
  1. Oct 14, 2018 at 5:54 PM
    Taco813
    Taco813 [OP] New Member
    2018 Black Tacoma SR5
    New owner here and I’ve been learning from these forums since I’ve bought the truck and received a lot of go information. So, I’m getting a 3/1 lift kit installed and going with the Fuel Krank 18x9 6x5.5 and Nitto Ridge Grappler 285/65/18 wheels. The shop doing the work recommended a 14mm offset. I like the aggressive look, so I’m worried these may not give me that effect. The installer said the tires would be about flush with the fender. Is this true? Any pictures who has a similar setup would be great help!
  2. Oct 15, 2018 at 8:54 AM
    hellaclean
    hellaclean Active Member
    Don
    San Diego CA
    2019 Toyota Tacoma TRD Off-Road
    I'm in the same boat as you and I'm undecided between 0 or -12 offset. You should check out the website customwheeloffset.com. You can filter it down to exactly what you are looking for.
  3. Oct 15, 2018 at 2:47 PM
    Taco813
    Thanks. I checked that site but unfortunately I couldn’t find that offset.
  4. Oct 18, 2018 at 5:53 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    You want it to rub and look mean over tucked in with less rub? Up to you. Pretty much can’t have both. Your choice.
  5. Oct 18, 2018 at 7:15 PM
    BCTRD357
    BCTRD357 Well-Known Member
    Jarrett
    2018 dcsb cement TRD off road
    none yet
    That wheel will be flush with the fender. It will look very similar to the 16x8 with 0 offset that many here have.
    You may rub on your UCA with that much backspace from what I hear...
    In a 9" wheel, I'd go negative offset.
  6. Nov 5, 2018 at 9:22 PM
    dowdib
    dowdib New Member
    positive offset rim is tucked into wheel well, negative offset rim moves out giving wider stance and more clearance
  7. Nov 6, 2018 at 6:06 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
