Offset Help!!
Discussion in 'Wheels & Tires' started by Rocket_03, Dec 20, 2024.
  1. Dec 20, 2024 at 6:05 AM
    Rocket_03
    Rocket_03 [OP] Member
    2020 Tacoma
    Alpha Rex quad pros Mbrp short off road exhaust Overland Torque tune S&B cold air intake
    Hey guys, I’m brand new here and I’m hoping for some help with sizing up and figuring out which offset is good for me. I’m purchasing a FiberWerx pre runner style 6 inch flare body kit (fronts and rears) and want my wheels to sit flush with the kit, how much of a wheel offset would I need to accomplish this?
  2. Dec 20, 2024 at 7:43 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    What does 6" flair kit really mean? If its actually 6" (thats insane), then the obvious would be at least an additional positive 6" (150mm).
    We also don't know what your rim width and offset is presently to base the new guesstimate off of. Are you changing width and rim size?
    gotoman1969 likes this.
  3. Dec 20, 2024 at 9:04 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Well it’s Friday!!
    RIX TUX likes this.
  4. Dec 20, 2024 at 1:13 PM
    Rocket_03
    2020 Tacoma
    @1 Limited Toyota those are both great points man, so FiberWerx advertises the kit at 6 inches of flair and 3 inches of rise. I’m not entirely sure if that equates to a “true six” or not. But I am keeping the width and rim size the same as stock or as close to stock as I can
  5. Dec 20, 2024 at 2:05 PM
    gotoman1969
    So if you’re keeping a stock size wheel what’s the plan to push out the wheel that far. It’s not gonna be possible. Plus if you even pushed a wider wheel out that far. The scrub radius is gonna horrible and make it pia to clear the cab mount. Also are doing any kind of lift or hight modifications?
  6. Dec 20, 2024 at 2:08 PM
    gotoman1969
    Looking on the FW website all those trucks appear to be running long arm kits on them. Is that your plan?
  7. Dec 20, 2024 at 4:14 PM
    Rocket_03
    2020 Tacoma
    Yes, I’m planning to do a full suspension swap (further down the road) which now that I’m thinking abt it would be a huge help to getting the offset and stance I want. Would control arms give me that major of a “bump out”? Because if that were the case I could probably get away with only slightly exposing my wheels and tires now and waiting on the FW kit.
  8. Dec 20, 2024 at 5:32 PM
    gotoman1969
    IMO. I’d do research as to exactly your plan and what’s needed. Then get all the funds together and do it all at once. Personally that’s what I’d do.
  9. Dec 20, 2024 at 8:10 PM
    Rocket_03
    2020 Tacoma
    Smart thinking. Thanks for the help today guys this really helped me iron everything out:)
  10. Dec 20, 2024 at 8:11 PM
    1 Limited Toyota
    California
    08 XRunner
    Cool your jets rocket-03. your getting the cart before the horse... or more like wheels before the mods... First things first. The mods will change the measurements.
  11. Dec 20, 2024 at 8:17 PM
    Rocket_03
    2020 Tacoma
    I’m definitely seeing that now, you guys seriously just saved me a ton of headaches (and most likely some wasted dough) I really appreciate it. I like what @gotoman1969 said about waiting till all my funds are in order and throwing everything on at once after some research.
    gotoman1969 and Finn-2187 like this.
