Offset? Level 8 strike 6
Discussion in 'Wheels & Tires' started by CRBCelica, Mar 6, 2012.
  1. Mar 6, 2012 at 7:53 AM
    CRBCelica
    CRBCelica [OP] Member
    Having a hard time finding the correct offset for the strike 6. 17x9 for my 2nd gen taco dbl cab sport pckg. Im not lifted so im not sure if ill have issues with rubbing and also what tire size would be best?
  2. Mar 6, 2012 at 2:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    with no lift you can fit 265/65/18 (be aware that some 265's aren't approved for 9" wide wheels) or some folks have been able to fit 285/60/18. You'll want 4.5" to 5.5" backspacing. with 4.5" backspacing it's possible you will have some minor trimming due to the wheel being 9" wide.
  3. Mar 6, 2012 at 6:17 PM
    CRBCelica
    5bs will be the max i should run with stock suspension correct? Also what exactly will need to be trimmed?
  4. Mar 6, 2012 at 6:52 PM
    KPT
    09 Prerunner
    Both of those questions depend on which tire size you select of the two i presented above.
  5. Mar 6, 2012 at 7:08 PM
    CRBCelica
    Im thinking bout going with 265/65.
  6. Mar 6, 2012 at 7:52 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
  7. Mar 7, 2012 at 5:32 AM
    KPT
    09 Prerunner
    Anywhere between 4.5" and 5.5" BS will work for that setup.
