Offset Needed For 33 Inch Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Britonish, Jan 17, 2023.
  1. Jan 17, 2023 at 9:19 PM
    Britonish
    Britonish [OP] New Member
    Briton
    2000 Tacoma TRD Off-road Extended Cab
    Hey guys! I need information if anyone has got it. I have a lifted 2000 Tacoma extended cab that I want to throw some bigger wheels and tires on. I want 33s on it. I just don’t know what offset I would need on the wheels to fit tires that size without hitting anything. Thanks guys!!
  2. Jan 17, 2023 at 9:26 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
  3. Jan 17, 2023 at 10:09 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    As @Nevin mentions, there are a lot of factors that go into rubbing. What size tire you can fit is a pretty common question here on TW (welcome!), so take a read through this post to understand how various elements play into the picture. Ultimately, with 33" tires (regardless of width), you're going to have to do a bit of work (pinch weld mod, and maybe some trimming of your flares) to get them to not rub (assuming you want to use the entire articulation of your suspension), but you can do yourself favors by keeping the wheel and tire widths relatively narrow (essentially, close to stock).
    By all means, if you don't follow any parts of this, feel free to ask questions!
    What size tires fit my (lifted) Tacoma?
    Area51Runner likes this.
  4. Jan 19, 2023 at 10:46 AM
    Britonish
    Briton
    New
    That makes a lot more sense! I read through it and I think that I’m finally starting to understand how all this tire size stuff works haha. Thanks a ton guys!!!
    turbodb[QUOTED] likes this.
  5. Jan 19, 2023 at 10:46 AM
    Britonish
    Briton
    Thanks!
    Taco critter likes this.
