offset negative rims or spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrWortWort, Feb 22, 2023.
  1. Feb 22, 2023 at 1:09 PM
    MrWortWort
    MrWortWort [OP] Well-Known Member
    2021 SR Access Cab Tacoma
    I have stock SR rims and I want to add bigger tires
    I was told I need spacers if I want to use my stock rims
    Should I get spacers or save up and get negative offset rims?
    Also how negative can I go that wont effect performance?
  2. Feb 22, 2023 at 1:22 PM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    Spacers are perfectly safe and functional when installed correctly.
    Spidertraxx is solid, I would avoid ebay knock-off spacers. The hardware maybe less than grade 8 which is a minimum.
    And stay 1.25 or below for wheel bearing sake.
    But, haters will always hate on spacers. Dont listen.
    hooliganrick likes this.
  3. Feb 22, 2023 at 1:26 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What size tire are you wanting to go with?
  4. Feb 22, 2023 at 1:28 PM
    MrWortWort
    What size of offroad tires can I get away with using stock SR rims?
  5. Feb 22, 2023 at 2:19 PM
    na8rboy
    WI
    265//75/16, 265/70/16, there is also the tall skinny option. None of these would require spacers. But if you want spacers, go with Bora, or Spider-Man. Don't cheap out.
