Offset no Lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan Reynolds, Nov 11, 2020.
  1. Nov 11, 2020 at 2:35 PM
    Ryan Reynolds
    Ryan Reynolds [OP] New Member
    2020 Toyota Tacoma trd off-road Premium
    LED headlights LED fog lights LED interior lights
    Hey how is everyone doing today I’m Ryan I recently bought a 2020 Tacoma off-road premium, I got a question I would like to get volk te37x 16x8 because It’s close to the stock rim size, I would just like to know what is the best offset to get without rubbing and lifting
  2. Nov 11, 2020 at 2:37 PM
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    ... tire size youre considering?
  3. Nov 11, 2020 at 2:38 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I thought they only came in 0
  4. Nov 11, 2020 at 2:45 PM
    Ryan Reynolds
    I’m thinking
    265/70R16 with a bit of aggressive thread
  5. Nov 11, 2020 at 3:10 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    When the thread matches the font...
    Here's the thing, I've got 265/70 r17s with a -12 offset on a stock height right now (actually about 1/2 inch lower than stock due to a winch). I was able to heatgun the plastic and trim the plastic lip at the bottom and eliminate 98% of the rub. I think I can get rid of the rest with a second go of the heat gun. With a smaller diameter tire (like 265/70 r16) I think my 9 inch wide -12 wheels would have cleared and if they didn't 5 minutes with a heat gun would have solved it. Basically if you stay close to stock you won't have problems. I think if you try for something like -34 offset you start to get into the realm of real work to remove rub.
    Ryan Reynolds[OP] likes this.
  6. Nov 11, 2020 at 4:11 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I have not had any rubbing issues with a -6 offset and 265/75r16s, but it’s close.
  7. Nov 11, 2020 at 5:29 PM
    Ryan Reynolds
    Thank you everyone I appreciate it I think the I will be going with 0 offset with 265 70 r16
  8. Nov 11, 2020 at 5:33 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Most go up one size 265/75/16 and experience no rub. You should be fine with this size, that's if you want a larger tire.
  9. Nov 11, 2020 at 5:43 PM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    I run 16x8et0 with 265/75/16 and have yet to rub anywhere.
