Offset OEM vs 17" TRD Gloss Gunmetal Gray
Discussion in 'Wheels & Tires' started by greymac, May 24, 2025.
  1. May 24, 2025 at 10:30 PM
    greymac
    greymac [OP] Well-Known Member
    Alaska
    2017 MGM LTD; 2012 Reg Cab
    I'm replacing the 2017 Ltd 18" stock wheels with 17" TRD Gloss Gunmetal Gray (PTR20-35110-G4) wheels.
    Using the calculator at and hung up on offset.
    For the OEM wheels, the calculator auto inputs 30, but I've seen both 18 and 25 listed elsewhere. Can't seem to pin it down.
    Is the offset for the TRD wheels 22?
    How much does this offset number even matter? Changing the values doesn't seem to change much in the outcome of the calculation.
    The parameters to the left (fender, wheel well and suspension clearance) were also auto input. Anyone know if those are correct?
