offset wheels on 07 tacoma ?
Discussion in 'Wheels & Tires' started by surftodd, Mar 14, 2008.
  1. Mar 14, 2008 at 7:40 PM
    surftodd
    surftodd [OP] Well-Known Member
    2007 Tacoma
    3 inch Trux suspension lift Upgraded Bilstein Shocks Upgrade spring pack Custom Rock-Crawler Wheels 32 inch Kumho MTs Rear Jumper Seat- makes truck a seven person vehicle Tow package Rear Fog lights New Roof Rack Running Lights Cargo Extender Rack Bed Cover
    :confused:I just wanted to get the census on putting off set wheels with 265/75 mud tires. I am planning on using a 2.5 inch lift in the front. How bad is the rubbing? I doesn't look like too much can be shaved off the mud flaps. One person suggested getting older style flaps. Does this happen just with 265/75's or with the next size down to? I know the offset wheels actually perpetuate a problem, but hey...where there is a will, there is a way.(usually):rolleyes:
  2. Mar 14, 2008 at 9:22 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    What are the wheel specs? (width & offset or back spacing)?
  3. Mar 14, 2008 at 9:43 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^^ What he said. All wheels have an offset measurement, even if its 0. I believe the stock wheels are -4.5 offset, and that's what I bought when I replaced mine with aftermarket wheels.
    When buying wheels, note that we're lug-centric.
  4. Mar 15, 2008 at 8:19 AM
    surftodd
    2007 Tacoma
    I'm think 16 inches x 8 or 10 wide.......
    I beleive about a +11 spacing
    Going for the wide-look on the tires if possible
