Offset.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastVanTaco, Jun 18, 2018.
  1. Jun 18, 2018 at 5:48 PM
    EastVanTaco
    EastVanTaco [OP] Well-Known Member
    2017 super white Trd Sport DCLB
    I have 5100s at the highest setting with 888 x coils, SPC uca's.
    275/70/17 BFG Ko2s
    My rims have a backspace of 4.75
    Offset of 0.
    I have ordered a different cheapo rim for a spare spare. I also got 5th tire the same as the other 4.
    The spare rim has the same backspacing 4.75
    But the offset is -6
    Will i have any issues? ??
  2. Jun 18, 2018 at 5:58 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Most likely no. It's only a 1/4" farther poke out than your 0 offset. If your closer than an 1/4'" clearance (lock to lock) it would be.
    EastVanTaco[OP] likes this.
  3. Jun 19, 2018 at 9:13 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    The spare will likely rub on full lock mounted up front. I wouldn't worry about it.
    just be aware its going to be close IF you ever get a flat tire.
    Always the option of swapping front to rear too if front tire gets a flat, then good to go.
  4. Jun 19, 2018 at 9:15 AM
    EastVanTaco
    This is what i was wondering.
    So it should put the rim about 1/4" farther inset?
  5. Jun 19, 2018 at 9:19 AM
    na8rboy
    WI
    1/4" out
  6. Jun 19, 2018 at 9:22 AM
    phsycle
    phsycle Well-Known Member
    CA
