OGE Dual Battery System - Always Combined?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rewted, Aug 14, 2017.
  1. Aug 14, 2017 at 2:36 PM
    rewted
    rewted [OP] Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    I have my OGE Dual Battery system installed and appears to be working (see previous thread in my history for back story) - It seems it's *always* in combine mode unless I lock it out.
    It doesn't switch over during start, but during the drive it switches over to combined and I'm failing to see the cause why.
    Any ideas?
    No additional battery loads yet like winch or anything, just stock truck electrical.
    I've been attempting to get a hold of Matt at OGE but he hasn't responded to me for 2 weeks after the initial consult on getting the system.
  2. Aug 14, 2017 at 2:53 PM
    N128CG
    N128CG Well-Known Member
    2017 Tacoma TRD OR
    Stock
    If I remember right the system stays connected until the main battery drops below a certain voltage. I can't remember what that voltage is off the top of my head. If you don't have any load on either battery it would likely take a couple of days before the voltage dropped to the point it disconnects.
  3. Aug 15, 2017 at 3:38 PM
    rewted
    @cblow5 Thank you, that doesn't, unfortunately, quite answer why mine is always combining with the stock electrical load. I'd understand if it needed it during starting or while running a winch, heavy light combo... but this is just driving down the road in a largely stock, electrically, tacoma.
    Just not sure I get it.
  4. Aug 15, 2017 at 5:07 PM
    rewted
    I see, I thought the combining portion was for the draw.. not for the charge as well.
    Thanks for clarification.
    cblow5 likes this.
  5. Aug 16, 2017 at 6:24 AM
    rewted
    That makes sense, I guess what was confusing me is if the load wasn't there why was it combining, but it sounds like that's also for charging when it drops below a certain voltage even if idle.. so it combines them to take care of both simultaneously.
    Cool, thanks again.
