Oh Crap thats the transmission not oil pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XGR50.2, Mar 12, 2010.
  1. Mar 12, 2010 at 11:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    nor do i...he came to ask if that slight amount of fliud would affect anything. sounds like come of the people here need to pack up to ttora or ct
  2. Mar 13, 2010 at 12:06 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    lol how many times will I see these threads, if you can't tell the difference between the two, than you should not try this. It's not rocket science.
    But everyone makes mistakes, good luck with future oil changes. Sorry if I sounded like an @ss (was not trying to), have a good one.
  3. Mar 13, 2010 at 6:19 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Couldn't find the Chris4x4 write up, did he do one as well?
  4. Mar 14, 2010 at 6:59 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I think its great that you are doing you own maint. A oil change is prob. The easiest thing you can do yourself. Get someone with a little experience to go over it with you as you can cause damage to a vehicle quite easily if you are not sure of the maint procedure.
  5. Mar 14, 2010 at 7:07 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2... not sure when TW turned into a Jr. TTORA...
  6. Mar 14, 2010 at 7:11 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    :thumbsup:
    This
  7. Mar 14, 2010 at 11:49 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  8. Jan 6, 2013 at 7:42 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    assuming he didn't swallow :eek:
  9. Jan 6, 2013 at 7:46 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    There is a place to add fluid you just need a pump which you can get for under 10 bucks.
