Oh No! What did I do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy4Eva, Dec 29, 2019.
  1. Dec 29, 2019 at 2:59 PM
    Toy4Eva
    Toy4Eva [OP] New Member
    JP
    2008 Silver Tacoma
    none
    Hello everyone. I'm a newbie to the forum. I replace the Coolant Bypass Pipe on my 2008 Tacoma 2.7L, I took the liberty of removing the Intake Manifold to better get to the area. Everything went well with the replacement but once I finished buttoning everything back together I discovered that I had this electrical connector not connected to anything as well as this Manifold port. I took everything back apart to see where the connector goes or a tube for the Manifold but I found nothing. I drove the truck and about 20 mins in the Check Engine Light came on. AutoZone ran a diagnostic and came up with Evaporative Emission System Incorrect PurgIMG_20191229_165622066.jpgIMG_20191229_165616263.jpg IMG_20191229_165518744.jpg IMG_20191229_165511213.jpg e Flow. Help would be very appreciated.
  2. Dec 29, 2019 at 3:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you missing a vacuum line? The last picture, in the middle.
  3. Dec 29, 2019 at 3:08 PM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    You may need to cut the wire tie off and see where your plug will reach. Unless it's a factory wire tie which it doesn't appear to be. Hoping somebody with a 2.7 can help you out. Mine's a 4.0.
  4. Dec 29, 2019 at 3:18 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Looks like you are missing the vacuum line that goes between the intake plenum and that evap switching valve. hence the evap code.
    And like stated, that zip tie does not look factory, looks like you might of put it there to keep that connector out of the way. cut it off so that connector can move its full range, then find the plug thats within the radius of the wire thats empty n plug her in.
  5. Dec 29, 2019 at 3:22 PM
    FJBub
    Doug
    See red circles. Just guessing that the one on right needs to be hooked up. The one on left is where plug might go. Like I said, I'm guessing but trying to help.
  6. Dec 29, 2019 at 3:33 PM
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    That electric plug looks to be the one that goes under the manifold to the vacuum switching valve.
  7. Dec 29, 2019 at 5:02 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    This is why I take a picture or multiple pictures from different angles before I take anything apart even if I've done it before but it's not common.
  8. Dec 29, 2019 at 5:12 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Oh Noooooooo!
  9. Dec 30, 2019 at 4:31 AM
    FJBub
    Doug
    Get it fixed?
  10. Dec 30, 2019 at 10:38 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This is exactly why I take lots of pictures before and during the process for anything that is even slightly complicated.
  11. Dec 30, 2019 at 4:16 PM
    suppra87
    suppra87 Well-Known Member
    Tim
    MD
    15' Black DCSB TRD OR
    The open vac port looks like the EVAP purge valve. It pulls intermittent engine vacuum on the fuel vapors in the tank in order to combust them efficiently. There should be a hose coming off the firewall within close vicinity to the fuel lines that will connect to that port. It will be a low pressure ~1psi for EVAP and will have a pinch type clamp on it.
    Your open electrical connector looks like it should connect to a pressure sensor of some sort, possibly goes to a idle up pressure sensor on the power steering high pressure line at the P/S pump.
