OH S@*T.. wrong fluids added!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by TIPICOTACO, Apr 21, 2011.
  1. Apr 21, 2011 at 6:36 AM
    TIPICOTACO
    TIPICOTACO [OP] Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Hey, so I've been experiencing a serious whine whenever I first start my truck in the morning. It goes away within a mile or so from home. I thought it was belts with the changing weather, but I was told that I was low on Power Steering Fluid so I went out and grabbed some and filled it up. The whine however still persists after a week.
    This morning I took another look at the bottle of fluid that I added and its for HONDA and ACURA only!!! :eek: WTF did I do?!?
    Is this gonna screw up my truck? If so how can I drain it and add the right fluid?
    TIA . . . . Tyler
  2. Apr 21, 2011 at 6:40 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    your screwed. jk. :) But seriously drain those fluids immediately and add the correct ones. Don't drive it till this has been done.
  3. Apr 21, 2011 at 7:02 AM
    TIPICOTACO
    Tyler
    nw nj
    well crap that's what I was affraid of. Does a professional have to do it? or is it as easy as an oil change (i doubt it :()
    thanks for the responses...
  4. Apr 21, 2011 at 8:07 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Should be running ATF fluid in your PS pump.
  5. Apr 22, 2011 at 11:29 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    I put powersteering fluid in my brake res once in my old 4runner. IT SUCKED. Once it cycled into the lines the brakes would lock up on one side of the calipers and vibrate like a s.o.b. DONT DO IT.
  6. Apr 22, 2011 at 11:32 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x2, for honda or not, your pump is ruined if you ran it with power steering fluid. supposed to be automatic trans fluid.
  7. Apr 23, 2011 at 8:35 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I would say the pump was bad before you did this, judging by the whine. Now it's definitely done for. I would take it to a shop and have them put a new pump in and bleed it all. Unless you can do it and save some labor cost.
  8. Apr 23, 2011 at 8:42 AM
    MillerMan06
    MillerMan06 Well-Known Member
    Adam
    Raleigh
    06 PreRunner SR5
    K&N Cold Air Intake,Running boards,bed cover,windows tinted, MagLite seat mount (A big Thankyou to piercedtiger for that one got it off cheap/free mods) extra 4 outlets on the 12V plug 3 12V plug in's and a USB all one box with toggles,48LED dome light (blue), Tail gate theft mod,Exhaust flowmaster super 44 with tips!!!!
    oooohhhh!!!!!!!!!!!! good luck!!! you might be able to save it. you will just have to try and see!!!! keep us updated on how it turns out!!!!
  9. Apr 23, 2011 at 10:39 AM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    yeah we put power steering fluid in the power steering pump and blew all the seals, apparently power steering fluid doesn't work for power steering systems :p have fun fixing it haha
