**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Nov 12, 2015 at 2:10 PM
    #2201
    simplehuman
    simplehuman Well-Known Member
    Question for you modification gurus..
    I recently removed one of the switch bank blanks under the HVAC controls and noticed that 1: it is already wired, and 2: it appears the appropriate switch could be easily attached to the harness and plugged right in.
    So here's my question:
    1. Is the switch bank in fact already wired?
    2. If so, what switch manufacturer/design fits in that spot?
    3. Where in the fuse panel do they attach?
    4. Does the wiring extend beyond the fuse panel and terminated elsewhere in the truck?
    Thanks for the info!
  2. Nov 12, 2015 at 3:21 PM
    #2202
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    What spot specificly? Was there a factory switch for that spot?
  3. Nov 12, 2015 at 3:31 PM
    #2203
    simplehuman
    The bank of three switches and the ipod/aux input. The A-TRAC button has two blanks on each side of it.
  4. Nov 12, 2015 at 3:34 PM
    #2204
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    Mine is set up from left to right, blank, A-Track, usb/aux, blank. Didn't the factory heated seats switches go in there? Possibly the blanks?
  5. Nov 12, 2015 at 3:38 PM
    #2205
    simplehuman
    Not sure. I want to put my auxiliary light switches in there but I don't want to rewire or reinvent anything if I don't have to. If I can find the right switch that plugs into the harness that's already there then that would save time, effort, and a LOT of patience.
  6. Nov 12, 2015 at 3:47 PM
    #2206
    outdoorwhore
    outdoorwhore Well-Known Member
    micah
    Lancaster/sugar grove ohio
    03 xcab
    bolt on stuff to make it go places
    Checks in the mail should be at your house Monday.
  7. Nov 12, 2015 at 3:55 PM
    #2207
    outdoorwhore
    micah
    03 xcab
    I need dates fast my turn for picking vacation is coming up!!!!!
  8. Nov 12, 2015 at 3:58 PM
    #2208
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    eBay has some switches that are a copy of the factory type and they have different designs. They fit into that old location perfectly and you just do the rest of the wiring for whatever yourself
  9. Nov 12, 2015 at 4:03 PM
    #2209
    simplehuman
    Thanks! So the wiring and wiring harness attached to the blanks don't go anywhere?
  10. Nov 12, 2015 at 4:06 PM
    #2210
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Everything on the truck comes pre wired. So one harness for every auto Tacoma and same with manual. Saves time on the line and costs. Only thing I've found not pre wired is the bed outlet. That's a separate system. There's a few other little things not included in the harness but for the most part it all is
    At least. From what I've been told
  11. Nov 12, 2015 at 4:12 PM
    #2211
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    have you seen these? They say they fit in the two switch locations in the trucks. lots of cool designs.
    I think the center switches they reference fit in that switch location under the HVAC. I have no experience with them but they appear cool.
    http://www.aironboard.com/online/toyota-replacement.html
  12. Nov 12, 2015 at 5:30 PM
    #2212
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Prewired is a relative term. It seems like you always need at least one expensive harness to get the job done...Like most things are wired through the firewall in some clever harness, but you need the ones from there to whatever accessory...
  13. Nov 12, 2015 at 5:42 PM
    #2213
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You just defined it an extra level. I know there are a few wires that go directly to switches for something on other models. Some other addons you need an extra harness
  14. Nov 12, 2015 at 7:41 PM
    #2214
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    So I found out what the noise coming from my diff was!
    iwashmycar likes this.
  15. Nov 12, 2015 at 7:42 PM
    #2215
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    ^^^looks fine
  16. Nov 12, 2015 at 7:43 PM
    #2216
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
  17. Nov 12, 2015 at 7:44 PM
    #2217
    WheelInTheSky
    G
    Jackson Hole
    Any idea what caused this?
  18. Nov 12, 2015 at 7:48 PM
    #2218
    bluewaters182
    Greg
    Ohio
    Not really? I went wheeling the week before, but didn't really go out crushing things. Plus it drove fine while out at badlands, then drove back 4hrs and the rest of the week with no problems, then all of a sudden thump thump thump. Maybe ECGS will know?
  19. Nov 12, 2015 at 7:52 PM
    #2219
    bluewaters182
    Greg
    Ohio
    On a positive note my awesome friend Matt is letting me drive this beauty while my Taco is down.
    iwashmycar and smithr1730 like this.
  20. Nov 12, 2015 at 7:52 PM
    #2220
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    ECGS will know that you need 4.88s and lockers
