**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Nov 15, 2015 at 4:35 PM
    #2321
    Moonlighter
    Moonlighter Active Member
    Blake
    Ohio
    03 V6 4x4 Xtra Cab SR5
    Okay thanks guys. So if I can turn the cam bolts does that mean that they are not seized up and caster should be able to be adjusted? He acted like he could not get them to turn at all
  2. Nov 15, 2015 at 7:33 PM
    #2322
    outdoorwhore
    outdoorwhore Well-Known Member
    micah
    Lancaster/sugar grove ohio
    03 xcab
    bolt on stuff to make it go places
  3. Nov 15, 2015 at 7:59 PM
    #2323
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I'm cool with it being mostly chill gravel stuff, starting to stress about how much I've put my suspension through since breaking that rear gas tube. I should really be blowing you off, but I just can't say no to a day of wheeling:goingcrazy:
  4. Nov 15, 2015 at 8:01 PM
    #2324
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Sounds about right, unless the 1st gen set up is different.. Didn't look like it though
  5. Nov 15, 2015 at 8:36 PM
    #2325
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    The bolt you may be able to loosen is what allows the caster cam to be able to be adjusted. You would have to loosen that bolt then put a wrench on the caster cam hex and see if you can move it (which of course if you can means you have to get another alignment, but of course sounds like you need one anyway). The cams do commonly seize up, so it would not be unusual if they are. The only solution is to cut the old ones out, and buy new ones (not cheap). I will be dealing with this soon myself unfortunately. Hope that makes sense.
  6. Nov 15, 2015 at 8:55 PM
    #2326
    bluewaters182
    Greg
    Ohio
    I think what you are referring to is known as cross caster. When they are not adjusted equally that can absolutely cause pulling to one side. When done by a someone who knows what they are doing, they can adjust the right side with a little more positive caster to compensate for the crowning of the roads. Not really sure how that affects tire wear, although if its pulling bad you would think it would wear incorrectly, usually toe is the culprit for uneven tire wear.
  7. Nov 16, 2015 at 1:40 PM
    #2327
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    No jury duty, let's rock this bitch
  8. Nov 16, 2015 at 2:25 PM
    #2328
    WheelInTheSky
    G
    Jackson Hole
  9. Nov 16, 2015 at 3:45 PM
    #2329
    Moonlighter
    Blake
    Ohio
    Thanks for the replies everyone.. got a better idea of whats going on now.
  10. Nov 16, 2015 at 5:03 PM
    #2330
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I am perpetually fucking lost at all times with this thread lol. Gotta check it like twice an hour it seems lol
  11. Nov 16, 2015 at 5:14 PM
    #2331
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Ahem. Language
  12. Nov 16, 2015 at 5:26 PM
    #2332
    MR2
    MR2 Master of none
    Massillon, Ohio
    The only OLD TACO in Ohio
    BUT WAIT THERE'S MORE!
    Couldn't get out of work for Tuesday. I'll have to catch it next time around, have fun guys.
  13. Nov 16, 2015 at 6:24 PM
    #2333
    WheelInTheSky
    G
    Jackson Hole
    Heard.
    Not your thread, bro.
  14. Nov 16, 2015 at 8:26 PM
    #2334
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    It does go in spurts
  15. Nov 16, 2015 at 8:29 PM
    #2335
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Is there an age limit? Old guys allowed?
  16. Nov 16, 2015 at 8:34 PM
    #2336
    WheelInTheSky
    G
    Jackson Hole
    Welcome to the muthafuckin max, sir. Old guys welcome, youthful ladyboys shall be tolerated.
  17. Nov 16, 2015 at 8:41 PM
    #2337
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    :bikewheelie2:
  18. Nov 16, 2015 at 8:57 PM
    #2338
    WheelInTheSky
    G
    Jackson Hole
  19. Nov 16, 2015 at 9:35 PM
    #2339
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    How old is "old"?
    I kind of got the impression I was towards the older end of the thread participant spectrum.
    Edit... shit, you're 44? I'm pretty close to that.
  20. Nov 17, 2015 at 5:24 AM
    #2340
    WheelInTheSky
    G
    Jackson Hole
    Leavin the house now. If no one hears from me for 24 hours I'm tied up in the basement of Lyons Den and Mark is using me for his pocket pussy.
