**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Feb 8, 2016 at 1:05 PM
    #4901
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I bet you'd love to see my face even more as it gets "processed"
  2. Feb 8, 2016 at 1:39 PM
    #4902
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    The head is supposed to be bigger than the shaft, that shit looks wrong.
    Oh yeah, welcome new guy! Hey, weigh in on the weirdness factor of that penis, willya?
  3. Feb 8, 2016 at 1:42 PM
    #4903
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    It should have said, "thanks for your continued support. You are now a Platinum member!"
  4. Feb 8, 2016 at 1:58 PM
    #4904
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    I say we plan a trip up there on a weekend over the summer..I might be able to convince my girl to go
  5. Feb 8, 2016 at 2:11 PM
    #4905
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    X2. Can hit all the wineries to stop their winering. They're pretty good though.
    I've been around up at Lake Leelanau however you spell it. Where's that in relation?
  6. Feb 8, 2016 at 2:39 PM
    #4906
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    that,s where I work.
  7. Feb 8, 2016 at 2:44 PM
    #4907
    smugly
    Doug
    I'll pass!!!!
  8. Feb 8, 2016 at 2:47 PM
    #4908
    WheelInTheSky
    G
    Jackson Hole
    x2 had the same thought when I saw it!
    Wow, only just joined the thread and you're already enthusiastically making a pass at Noodle's oddly shaped peen.. You'll fit right in!
  9. Feb 8, 2016 at 2:52 PM
    #4909
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Says the one who ordered from me.
  10. Feb 8, 2016 at 2:53 PM
    #4910
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Nice. I work just by the city hall
  11. Feb 8, 2016 at 6:00 PM
    #4911
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Who am I, Johnny Garmin? I dunno.....?
  12. Feb 8, 2016 at 6:01 PM
    #4912
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    I thought it was Mark Garmin. Are you related to Johnny?
    But yeah I was way off. 8.5 hours away.
  13. Feb 8, 2016 at 6:06 PM
    #4913
    WheelInTheSky
    G
    Jackson Hole
    @MeefZah I rly hope your prediction isn't accurate:pout:
  14. Feb 8, 2016 at 6:52 PM
    #4914
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    That your truck is out of service?
  15. Feb 8, 2016 at 7:03 PM
    #4915
    WheelInTheSky
    G
    Jackson Hole
    Yep, I tried multiple fastener companies but none have the correct metric bolts for my application. Also, their SAE sizes wont do as my application necessitates a level of accuracy that means compensating with SAE sizes is out of the question. I am now stuck waiting on an order for new shackles (I only need the hardware, but buying the shackles is the only means to that end.) I'm afraidd that the likelihood of said shipment arriving on Wednesday is quite low, and that is the latest date they could arrive that would still afford me sufficient time to acquire an alignment before the RRG trip.
    Fuck, you were right. I was hoping you wouldn't be..
  16. Feb 8, 2016 at 7:05 PM
    #4916
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    I think there is more SAE than metric on my truck.. But I really give no fucks cause it ain't no mall crawler
  17. Feb 8, 2016 at 7:09 PM
    #4917
    WheelInTheSky
    G
    Jackson Hole
    I don't mind using SAE in place of metric, yet there are certain applications where that is not feasible. I can't use SAE for my shackle hanger bolt because the difference between metric and SAE at that large of a size is too monumental to be negligible as it would be with smaller sizes. Also, none of the fastener suppliers in Ohio carry the size of metric bolt that I need with partial thread... if I go with full thread I will chew through the bushings within a week or so.
  18. Feb 8, 2016 at 7:12 PM
    #4918
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Unless your bushings are different, there is a metal sleeve that the bolt goes through and doesn't contact the actual bushing. So idk what you are talking about
  19. Feb 8, 2016 at 7:15 PM
    #4919
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Bummer.
    Maybe there's a lesson here about procrastination?
  20. Feb 8, 2016 at 7:16 PM
    #4920
    WheelInTheSky
    G
    Jackson Hole
    Yes, and the SAE bolt would either be too large to fit through said sleeve or it would be too narrow. The metric, on the other hand, would be fully threaded which is a no go. Furthermore, the hanger bolt for the shackle does not have the metal sleeve that you speak of, it has bushing on bolt contact. There is no size of SAE to fit those bushings, and I can not get the right size of metric without spending almost as much on the bolts washers and nuts as I would spend on a brand new greaseable shackle kit.
    Believe me, I've looked at it from every angle, and the head is too small for the shaft. "Just the tip" is supposed to be greater than an extension of the shaft...:luvya:
