**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Feb 11, 2016 at 1:22 PM
    #5041
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Awesome, thanks for the input.
    Headed there now, after I return a carbide drill bit to Lowe's that I bought an hour ago and realized was BENT when I got home. Really? Bent? A carbide drill bit... :annoyed:
  2. Feb 11, 2016 at 4:43 PM
    #5042
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I think that depends on the grease you put in there and where you store it. I have one of the standard ones from the parts store. Works well, but it leaked like a muther with that red M1 synthetic grease. I have since changed to the black M1 stuff and it has been great.
  3. Feb 11, 2016 at 4:45 PM
    #5043
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Once you go black, you never go back
  4. Feb 11, 2016 at 5:02 PM
    #5044
    WheelInTheSky
    G
    Jackson Hole
    I didn't pull the trigger at autozone today. I was looking at the mini grease gun they sell. It takes the 3oz cartridges. I was apprehensive about buying it, mostly due to the fact that their selection of grease looked like horse shit. I need to figure out what the best type of grease is to use... I know "synthetic grease" seams to be the standard, by I want to know what the fuck is in it. I would much prefer to use a highly concentrated molly grease. I just need to make sure I can get it in 3oz tubes. I know that the tubes I can get are something like $100 a tube, but luckily I get them for free. I'll do some research before pulling the trigger.
    Any of you used the mini Vatozone grease gun?
  5. Feb 11, 2016 at 5:10 PM
    #5045
    MR2
    MR2 Master of none
    Massillon, Ohio
    The only OLD TACO in Ohio
    BUT WAIT THERE'S MORE!
    I wouldn't get the mini grease gun, I have one that I bought actually for my lawnmower but selection is limited for those little tubes. The one I have actually doesn't have a flexible hose on it so that made it difficult to grease certain things when I went to use it on my truck.
    Found a decent gun at wal-mart for $15, don't remember the brand. I use the lucas red and tacky or whatever its called grease.
  6. Feb 11, 2016 at 5:12 PM
    #5046
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    This is what Total Chaos recommends for their stuff and what I use.
    Super Lube 41150 Synthetic Grease (NLGI 2), 14.1 oz Cartridge https://www.amazon.com/dp/B0042FG74W/ref=cm_sw_r_cp_awd_KftVwbDBR021E
  7. Feb 11, 2016 at 5:39 PM
    #5047
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Yeah get the one w the flexible hose. Makes all the zerks much more accessible. It would be damn near impossible without rotating the drivetrain, without one. I think Toyota just likes he NLGi2 grease. Check the manual and see what works but the standard synthetic stuff seems to fit the bill for all of it.
  8. Feb 11, 2016 at 5:42 PM
    #5048
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    I would look at Amazon, advanced auto, or napa. My faith in autozone is pretty limited.
    Used to love carquest, but they got bought by advanced, so they have a good selection of quality parts.
  9. Feb 11, 2016 at 8:01 PM
    #5049
    WheelInTheSky
    G
    Jackson Hole
    Well... the reg size gun at autozone doesn't come with a flex hose, it has a steel extension. That's the $15 one. The mini one has the flexi hose...
  10. Feb 11, 2016 at 8:19 PM
    #5050
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Yeah, I had to buy the extra flexible house part and attach it. I figured I would do it before it gets all greasy and slippery like most long tube shaped objects do
  11. Feb 12, 2016 at 3:39 AM
    #5051
    simplehuman
    simplehuman Well-Known Member
  12. Feb 12, 2016 at 4:54 AM
    #5052
    simplehuman
  13. Feb 12, 2016 at 5:04 AM
    #5053
    simplehuman
    And that's why I'm asking.
    Reviews say they are getting an increase in HP and MPG, but I'm not one to trust reviews of the biased. I did add a K&N COI and had a little gain in HP and MPG. But I took it off last winter (I always remove it during the winter) and replaced it with a K&N air filter with the OEM air box and got the same results jsut with less noise.
  14. Feb 12, 2016 at 5:06 AM
    #5054
    simplehuman
    From Amazon:
    Question:
    How well does this work on 2012 Tacoma O/R TRD 4.0 V6 with OEM Air Intake ?
    Answer:
    Hello Christopher , well what I can tell you is that it will attach and work , depending on the OEM intake there may be some slight fabrication that may have to be done whether it's the screws that come with the kit or modifying the air box in some way but it will work , expect smoother RPM levels between shifts and overall acceleration increase , nothing will be massive but I like to call it an across the board gain , rpm, mpg's , hp, etc.. You will not be disappointed .
  15. Feb 12, 2016 at 5:10 AM
    #5055
    simplehuman
    And there you go! Thanks!
  16. Feb 12, 2016 at 5:20 AM
    #5056
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    For all my years working on and modding engines a TB spacer is not worth the money you spend. Spend that $ on another mod.
    MR2 and simplehuman like this.
  17. Feb 12, 2016 at 5:53 AM
    #5057
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    I already committed to cancel the trip yesterday based on the weather forecast. But I'm somewhat disappointed how much the forecast changed from yesterday to today. Had I seen the forecast they posted today, I would have still gone down. Oh well, I know the weather folks can't always have it all nailed down. Matt you will see when we finally get down there, if there is ice, just getting around on the roads down there would be sketchy, let alone the trails. We'll all get it together and make it down there soon. I won't be able to make it the next two weekends because of hockey. I'm excited to go though, especially if the weather warms up a bit.
  18. Feb 12, 2016 at 6:19 AM
    #5058
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Wally World is where I got mine actually...This is the one I have had for many many years now. Comes with the hose, and still working well: http://www.walmart.com/ip/Lubrimatic-Pistol-Grease-Gun-with-Hose/16777574
  19. Feb 12, 2016 at 6:24 AM
    #5059
    bluewaters182
    Greg
    Ohio
    Well now LBL will be your shakedown for RRG. I've never been to LBL, but from pics I think RRG will have more challenging terrain than what I've seen in this forum.:notsure:
  20. Feb 12, 2016 at 7:17 AM
    #5060
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    So now that it's February and we are only 4 months away from rolling out. Who's going to RT?
