**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Mar 4, 2016 at 10:19 AM
    #5701
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I should take a torch to it?o_O Umm... ok I guess I'll take a torch to it:laser:
    Yeah, that was it. It was p0420 and p0421. I remember now because at the time I thought the autozone guy was trying to communicate via stoner code that he needed a smoke break and I was all like: "nah man, I don't do that anymore," and then he was kinda confused so I left.
  2. Mar 4, 2016 at 10:42 AM
    #5702
    intoit247
    intoit247 Well-Known Member
    steve
    Broadview Heights
    dcsb trd off road
    Roof rack, Led headlights , Led fog lights, Led backup lamps, black tail lights, bed mat, trailer brake , turn signal mirrors, scoop hood, painted grill bezel, headlight bezel paint, 3rd brake led. Tape on vent visors, rear slider visor. Driver heated seat. Wireless video on entune. TRD shift knob, TRD plate brackets front and rear. Led front switchbacks and led rear turn bulbs. AAL. 1 inch rear block. 3 inch lift front strut spacer. FIA front seat covers. Lighted 4x4 switch from 4 runner. TRD sport 17 wheels w kumho mud terrain tires..
    Are you trying to pass emissions test or just want lite off?
  3. Mar 4, 2016 at 10:43 AM
    #5703
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    My van had those codes and I put some spark plug non foulers from advanced on and spaced out the o2 sensors and now I'm golden for two years
  4. Mar 4, 2016 at 10:45 AM
    #5704
    WheelInTheSky
    G
    Jackson Hole
    I'm trying to get my sensor readings in the right voltage range. The end goal isn't to get rid of the light or to pass emissions.
    As for the hand brake, I drive a manual so it would be really nice to have that back. Are you sure taking a torch to the back of the drum is alright?
  5. Mar 4, 2016 at 10:55 AM
    #5705
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Emissions are a joke, I'm so glad Ohio got rid of their testing. Good luck in russiafornia
  6. Mar 4, 2016 at 10:55 AM
    #5706
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    I torched the ball crank pivot three times on my 02 .Brake worked fine. Just heat till it frees up. Then coat with some anti seize or grease.
  7. Mar 4, 2016 at 10:57 AM
    #5707
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Emmisions in cali are a whole nother animal
  8. Mar 4, 2016 at 11:00 AM
    #5708
    bluewaters182
    Greg
    Ohio
    Oh I know, their genious just shines, look at what that state did to all the "legal" gas cans. :annoyed::crazy::facepalm:
  9. Mar 4, 2016 at 11:00 AM
    #5709
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Catalyst monitors are not required in Ohio unless you fail initially. Then on retest they are required. If you time it right you can sneak them through with bad cats or no cats as long as they can see something that looks like a cat in the mirror.
  10. Mar 4, 2016 at 11:03 AM
    #5710
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    I lived in cali from 80 to 84. Overrated. The bonus is all the crap blowing or washing over from fukashima
  11. Mar 4, 2016 at 11:04 AM
    #5711
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    Thats what I did when I had my '94 Z28. Cat was hollowed out. Long tubes and open exhaust... damn it was a beast. But when the state trooper saw the cat housing he was like... well ok?
  12. Mar 4, 2016 at 11:20 AM
    #5712
    WheelInTheSky
    G
    Jackson Hole
    Don't get me started on Cali emissions testing. The rules are fuckking apeshit. I took my Ranger to get SMOGed and passed the emissions test. I failed the SMOG because i had a check engine light. You have to have 2 codes for a CEL, if you have one code and no CEL you are fine. If you have a CEL you instantly fail smog. Why did I have two error codes? They were the two consecutive error codes for running LEAN. LEAN! I failed emissions because i was burning less gas per mile than every other Ford Ranger on the fucking road.
  13. Mar 4, 2016 at 11:26 AM
    #5713
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Actually if you have lean codes it was putting excess fuel to compensate. Causing a rich condition. Being ford probably had dirty maf sensor causing the altitude calculation to be off.
  14. Mar 4, 2016 at 11:29 AM
    #5714
    bluewaters182
    Greg
    Ohio
    Im all for keeping stuff as clean as possible, but when things swingtoo far the other way it seems that it is not helping the cause that was originally intended.
  15. Mar 4, 2016 at 11:30 AM
    #5715
    WheelInTheSky
    G
    Jackson Hole
    Sry, I said it the wrong way round. My truck was running leaning. I forget what the codes were, just that they were caused by a lean condition.:smack: i haz teh stupidz
  16. Mar 4, 2016 at 11:38 AM
    #5716
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Most Fords get p0171, p0174. System lean bank 1 and system lean bank 2.
  17. Mar 4, 2016 at 11:41 AM
    #5717
    WheelInTheSky
    G
    Jackson Hole
    That faintly rings a bell. I had a competent mechanic at the time helping me to get the truck to pass SMOG. We collectively agreed I should give up and sell the truck when he realized that the fuel pump was held on by bits of wire that had been wrapped around it:anonymous:
  18. Mar 4, 2016 at 12:05 PM
    #5718
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    I had a smash Derby Ford tbird after I passed the inspection went to pull out in the field and it died. Had to tow it home and put an inline pump with a hose straight to bottom of tank with no sock on it. Worst part is they put me in a heat with all front wheel drive cars. I didn't last 10 min.
  19. Mar 4, 2016 at 12:10 PM
    #5719
    WheelInTheSky
    G
    Jackson Hole
    Inline fuel pump is pretty bad I have to say.
  20. Mar 4, 2016 at 12:13 PM
    #5720
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    If you happen to frequent OSU campus area or Mt Carmel east on a regular basis you are welcome to borrow mine. I have a Midlands and extra Lil Wil ready to go. I mention those areas for ease of dropping back off.
