**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Mar 5, 2016 at 4:54 PM
    #5781
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Is it an actual hitch or that US general winch bumper plate thing?
  2. Mar 5, 2016 at 4:58 PM
    #5782
    intoit247
    intoit247 Well-Known Member
    steve
    Broadview Heights
    dcsb trd off road
    Roof rack, Led headlights , Led fog lights, Led backup lamps, black tail lights, bed mat, trailer brake , turn signal mirrors, scoop hood, painted grill bezel, headlight bezel paint, 3rd brake led. Tape on vent visors, rear slider visor. Driver heated seat. Wireless video on entune. TRD shift knob, TRD plate brackets front and rear. Led front switchbacks and led rear turn bulbs. AAL. 1 inch rear block. 3 inch lift front strut spacer. FIA front seat covers. Lighted 4x4 switch from 4 runner. TRD sport 17 wheels w kumho mud terrain tires..
    Tried to get a picture of it. Search mobtown off-road
  3. Mar 5, 2016 at 4:59 PM
    #5783
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    It's an actual 2" hitch reciever
    Tretiak30 likes this.
  4. Mar 5, 2016 at 5:01 PM
    #5784
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    I bought the license plate bracket also.
  5. Mar 5, 2016 at 5:34 PM
    #5785
    WheelInTheSky
    WheelInTheSky [OP] Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Yeah, you should really melt some solder wire on to the end of the pin and file it down. The connection itself is on the sides of the pin, but the connection will be much better if soldered. No worries, I'd rather cut the connector off so I can snake the wire through my firewall more easily and add a connector after installation;)
  6. Mar 5, 2016 at 6:02 PM
    #5786
    MR2
    MR2 Master of none
    Massillon, Ohio
    The only OLD TACO in Ohio
    BUT WAIT THERE'S MORE!
    My favorite... :puke:
    Alright see you guys there, whoever shows up. @MeefZah @WheelInTheSky @intoit247 Anyone else?
  7. Mar 5, 2016 at 6:04 PM
    #5787
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Do you actually know what you are doing?
  8. Mar 5, 2016 at 6:06 PM
    #5788
    WheelInTheSky
    G
    Jackson Hole
    Yep, this is coax connector 101. The outside of the pin is waht connects to female connector, the solder point on the end of the pin and end of the copper wire is the best connection point between the coax and the male connector. Some people take the extra step of soldering the frayed ends of the ground at the base of the male connector but I trust the compression enough to do the trick:thumbsup:
  9. Mar 5, 2016 at 6:08 PM
    #5789
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    That's the easy part but do you know how to cut back the sheathing and foil sleeve to add the new connector.. That's the hard part young one
  10. Mar 5, 2016 at 6:11 PM
    #5790
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    That was actually put on by a professional radio shop - Staley Communications. I watched the guy do it. They use a special crimper to make the connection and solder is unnecessary. But you go ahead and jizz some solder on it if it will make you feel better.
  11. Mar 5, 2016 at 6:12 PM
    #5791
    WheelInTheSky
    G
    Jackson Hole
    Lol no it's not. I can run an exacto knife around the circumference of a cable. The rubber sleed is mad easy, the foil shield is just a matter of finding where the wrap ends and peeling it up like a bit of tape.
  12. Mar 5, 2016 at 6:13 PM
    #5792
    WheelInTheSky
    G
    Jackson Hole
    I hear ya. I fiddled with it and it looks very much compressed, I'm sure that it is at least 95% as good as if it were soldered but I don't mind taking the extra step of arseing around, especially when it means arseing around with a blowtorch!
  13. Mar 5, 2016 at 6:14 PM
    #5793
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You make me so proud 22bd2d0485f0b4a96e103d23925b9c4c_8a913f2d155521b0d0f10da45f2130b395076a6e.jpg
  14. Mar 5, 2016 at 6:16 PM
    #5794
    WheelInTheSky
    G
    Jackson Hole
  15. Mar 5, 2016 at 6:17 PM
    #5795
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
  16. Mar 5, 2016 at 6:30 PM
    #5796
    WheelInTheSky
    G
    Jackson Hole
    Good night.
  17. Mar 5, 2016 at 6:33 PM
    #5797
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You ain't going anywhere. I know you
  18. Mar 5, 2016 at 6:37 PM
    #5798
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    Now you need chrome pinup girl mudflaps.
    Tretiak30[QUOTED] and MR2 like this.
  19. Mar 5, 2016 at 6:42 PM
    #5799
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    No go for me tomorrow. I was up past Millersburg today. Picked up large greenhouse for friend in Amish country.
    Tomorrow I promised to help frame up walls for his new shop. Allows me access to a lift any time.
  20. Mar 5, 2016 at 6:57 PM
    #5800
    MR2
    MR2 Master of none
    Massillon, Ohio
    Like to install sliders? ;)
    I'll get your number from you soon and we can organize when our stuff comes in from allpro. Tracy said we should have stuff shipped in just a couple of weeks or less.
