**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Jan 25, 2018 at 10:20 AM
    TheRealKrobar
    TheRealKrobar Well-Known Member
    Columbus, Ohio
    2013 Black 5-lug Access Cab
    Just got the call, my truck is finally finished being fixed from the dealer!!! Pics maybe later if it's still light enough out when I pick it up.
  2. Jan 25, 2018 at 10:33 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Your LCA cam tabs are probably flattened. So youd want new ones welded on. Stock UCAs have no adjustment whatsoever, so if it is coming out of alignment its due to the LCAs
  3. Jan 25, 2018 at 10:36 AM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    What is the issue? Like Adam said, uppers have no alignment unless they are heimed. Check your lower cams and they are probably flat, or you have really worn out LCA bushings or a bad tie road or steering component.
    I weld and can fix that shit :D
  4. Jan 25, 2018 at 11:47 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    It probably is the tabs if I had to guess. Last time I had it aligned they said that they had a difficult time getting it completely straight. My truck is only a couple years old with 20ish thousand so I don't think it would be any bearings yet.
  5. Jan 25, 2018 at 11:49 AM
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    20k? I doubt the actual tabs are flat.
  6. Jan 25, 2018 at 11:57 AM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You’d be surprised.
  7. Jan 25, 2018 at 12:02 PM
    i_cappi
    Canton, Oh
    It's so hard to believe though. That's hardly any miles.
  8. Jan 25, 2018 at 12:05 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Just like LCA bushings/bolts being froze before salt even hits? Haha
    dirty deeds likes this.
  9. Jan 25, 2018 at 12:05 PM
    i_cappi
    Canton, Oh
    That's believable though!
  10. Jan 25, 2018 at 12:08 PM
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    My tabs were on the way out when I got it aligned at 45k
  11. Jan 25, 2018 at 12:25 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Yeah I had to try and hammer mine back out just to try and keep them holding the cams. I need to just get the Total Chaos (or whoever makes them) ones and weld them in. Woof.
    And hell, I bet the damned cams seize on the truck on the way to the dealership. Such a huge problem. You could go and have 3 dozen alignments and the techs wont even mention it...if it doesn't move they just try the others until the machine goes green.
  12. Jan 25, 2018 at 12:42 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    You all need to take your LCAs apart more often it sounds like :anonymous:
  13. Jan 25, 2018 at 12:53 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    If you can bend your stock tabs back 90* just place a weld behind them and save yourself $80
  14. Jan 25, 2018 at 1:00 PM
    i_cappi
    Canton, Oh
    Dealership did the same to me when I was in for a 2nd alignment. 1st time they failed to mention my cams and the tie rod ends were siezed
  15. Jan 25, 2018 at 1:10 PM
    dirty deeds
    Nick
    Eastern KY
    I bent one or two of mine, marginally, at some point after my second time swapping the front shocks. It happened while wheeling. Was able to tap with a hammer back into place
  16. Jan 25, 2018 at 1:54 PM
    Naumoff42
    Ohio
    2015 TRD Offroad
    I don't really know what I'm looking at when it comes to that stuff :anonymous:
  17. Jan 25, 2018 at 1:57 PM
    dirty deeds
    Nick
    Eastern KY
    The tabs should be 90° on either side of the alignment cam.
  18. Jan 25, 2018 at 3:16 PM
    TheRealKrobar
    Columbus, Ohio
  19. Jan 25, 2018 at 4:14 PM
    Naumoff42
    Ohio
    2015 TRD Offroad
    Just checked, my tabs look pretty perfect
    dirty deeds[QUOTED] likes this.
  20. Jan 25, 2018 at 4:51 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Lies.
    gunn_runner likes this.
