**OHIO WHEELIN' & MEET-UP THREAD**
Discussion in 'Ohio' started by WheelInTheSky, Apr 23, 2015.
  1. Jun 12, 2018 at 6:29 PM
    NickL
    NickL Well-Known Member
    Nick
    Columbus
    2012 DCLB TRD Sport
    I guess it’s been a while since I’ve been on here actually haha. Moab was fun too 8C3BE97A-E6E1-4A07-B552-1B4566ECC8A4.jpg 6383A0FF-FD60-44FF-8EFF-CE3A1963B7C9.jpg917BE842-AD6C-486C-B2BC-771AB37E2565.jpg
  2. Jun 12, 2018 at 8:13 PM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Anyone want to let me rent/borrow a rooftop tent for a weekend end of this month? Figured I'd give it a shot lol
  3. Jun 13, 2018 at 1:29 PM
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    TRD PRO suspension for sale. Willing to ship. PM for price Cincinnati OH area/Northern Kentucky
    20000 miles on rears 25000 on front. Mostly highway driving. a few minor scratches on the rears, but in great condition otherwise.
    [​IMG][​IMG]
    musher and crazyaussie like this.
  4. Jun 21, 2018 at 4:53 AM
    simplehuman
    simplehuman Well-Known Member
  5. Jun 21, 2018 at 9:02 AM
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    I've been trying to figure out how to get a larger inverter. I'd like to run my table saw. I'm guessing 400w won't cut it.
    I was considering upgrading the OEM unit, but it sounds like it's really integrated, with a breaker built into the button. So I was considering installling a second one, and putting the outlet on the driver side bed compartment, directly across from the OEM outlet.
    A larger inverter takes some serious DC electrical considerations as well. Started doing the math on DC current, and the mental excercise started to fall apart. Probably easier just to bring a Genny. Lol.
    tacofort likes this.
  6. Jun 21, 2018 at 9:09 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Well a lot of table saws are like 15 amps....so running on 110V would be 1650 Watts. Gonna need a heck of an invertor to get that.
  7. Jun 21, 2018 at 9:12 AM
    simplehuman
    I tried using a small 110V tree saw on mine and it ran, but there just wasn't enough juice. A table saw would probably push it, too. I have a 1000W inverter generator, the kind you use for tailgating, and that thing even had trouble running a shop fan and 7.5" circular saw. Just too much draw on it. I'm thinking this 1000W inverter will be enough to run my 8 gal. compressor. That would probably be the biggest draw on it.
    The nice thing about this model is it plugs into the 12V plugs in the dash so no significant wiring needed. Just run it under the floor mat.
  8. Jun 21, 2018 at 9:13 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Even if you had like a 2000W invertor...the truck wont sustain voltage to supply it....I bet at idle, with nothing else on, you might get 800W available from a stock alternator.
  9. Jun 21, 2018 at 9:14 AM
    tacofort
    Joe
    Cincinnati, OH
    I'm mounting a 2300 Watt inverter, but also have added more batteries. I have a 200AH, 75AH, and 55AH batteries. The stock alternator only puts out 130 amps, less when at idle. The alternator takes 2 AWG wires. LOL. So 50' of that and the lugs weren't cheap. Hoping to install soon, maybe this weekend.
  10. Jun 21, 2018 at 9:15 AM
    tacofort
    Joe
    Cincinnati, OH
    I think the big thing is enough capacity to run for short duration, and just watch your stuff to not drain the system.
  11. Jun 21, 2018 at 9:17 AM
    simplehuman
    I thought the Off Road HD alternators were enough to run a 1200 or 1500 watt inverter? This is just what I was told so I have not researched yet.
  12. Jun 21, 2018 at 9:20 AM
    simplehuman
    Correction.. The 12V from the dash caps out at 120W.
  13. Jun 21, 2018 at 9:32 AM
    tacofort
    Joe
    Cincinnati, OH
    Good point. Most of the accessory ports are thin wires and aren't designed for big stuff. My Snomaster fridge came with a 12V plug, but it got hard wired and hooked with 10AWG all the way. For a 1000 Watt inverter, and 15 feet or so of wire to get there, 1000Watts/12 volts~83 Amps, call it 85 amps. When I use the wire calculator, it suggested 4AWG wire. Basically, welding cable. Lol. And you'll want an extra wire for the grounding of 8AWG or so. It's beefy, but should be good.
    I think the big thing for me and inverters is the ability to have power somewhere I wouldn't normally and large enough that if my area lost power for a few days, I could use the system to keep my home fridge alive.
  14. Jun 21, 2018 at 9:39 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    You can plug in a 1500W invertor all day long as many do. However most dont use all that wattage. Maybe 200 here, 600 there.
    I was basing that off a conservative half-of-what the alternator can put out max....so 130A alternator is probably only 1300W available MAX. Gotta run the truck too.
    simplehuman[QUOTED] likes this.
  15. Jun 21, 2018 at 2:31 PM
    k8md
    Bob
    My table saw is a small portable one. Still, I was aiming at a 15 amp outlet, and came up with needing a 2000w inverter. After doing the DC voltage math and wire sizing, the project was a no go.
    I wouldn't need continuous duty for a long duration. A few seconds to rip some boards. It would require a hefty battery bank, and then allow the OEM (or aftermarket) alternator to recover the battery bank.
    It's cheaper, easier, and more versatile to just buy a Honda e2000, to accomplish my goals. The inverter is a luxury I can live without.
    iwashmycar[QUOTED] likes this.
  16. Jun 21, 2018 at 3:03 PM
    15tacomaTRD
    15tacomaTRD Well-Known Member
    NE Ohio
    2015 Tacoma TRD Off Road
    I remember @MeefZah, after that time we all met up like 3 years ago, with Gavin. Yea ohio sucks for off roading!
  17. Jun 21, 2018 at 3:23 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You were in that? One of the original Ohio gangsters yo.
  18. Jun 21, 2018 at 3:53 PM
    15tacomaTRD
    NE Ohio
    Yes sir. It was like two weeks after i got my truck.
    Tretiak30[QUOTED] likes this.
  19. Jun 22, 2018 at 8:43 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I believe this be you, chilling with Anna...
    15tacomaTRD[QUOTED] likes this.
  20. Jun 22, 2018 at 8:45 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    15tacomaTRD and simplehuman like this.
