Oil additive recommended by dealer is it bs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1933beer, Sep 28, 2022.
  1. Sep 29, 2022 at 9:30 AM
    #41
    Wulf
    Wulf no brain just damage
    rock raisin
    Changing their clogged fuel filters
    Idaholandho[QUOTED] likes this.
  2. Sep 29, 2022 at 9:55 AM
    #42
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I had the same experience also. I must have a good dealer. Our driveway has a big White Birch tree next to it. For a couple months in the spring, that tree spits pollen like crazy. At my 15K / 30K services the air/cabin filter were... Not terribly... But enough that the dealer felt they needed changing. They changed them. On the house.
  3. Sep 29, 2022 at 10:01 AM
    #43
    1933beer
    1933beer [OP] think global drink local
    Iowa
    22 TRD sport, premium and tech package crush blue
    none
    They have oild additive on the report.
    I do put seafoam cleaner in my cars that i dont drive in the winter. When i first got my 85 celica gts it ran fine but i added a bottle to a full tank and i was surprised at the change. I do recommend using it in small engines that sit for long periods like snow blowers and chain saws.
  4. Sep 29, 2022 at 10:04 AM
    #44
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Doing your 1st oil change at 5K would be much more beneficial to the long term health of your engine than paying them $20 to pour snake oil in there. Get those initial break-in metal particles outta there. I do 5K oil changes standard (because there’s plenty of evidence out there that doing 10K changes is pushing it if you want your engine to make it to 300K+). But I think the first oil change at ~5K is the most important.
  5. Sep 29, 2022 at 10:04 AM
    #45
    1933beer
    Iowa
    none
    Ya that is what i see toyota care being. If it needs it they do it. They wanted $64 for a cabin filter. It costs about $15 and 5 minutes to change. I told them i would take care of that.
  6. Sep 29, 2022 at 10:08 AM
    #46
    BMH
    Bruce
    :thumbsup:
    When I went in for my very first servicing, I spent 10-15 minutes talking 'tech' to the service manager. I was my way of letting him know 'You're not talking to a teenage kid who has never had auto shop, or someone who hasn't done maint/repairs on my own car/truck for 50 years..'
    whatstcp[QUOTED] likes this.
  7. Sep 29, 2022 at 10:46 AM
    #47
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Truck has D4-S…Toyota language for both port and direct injection.
    Other than taking advantage of port injection when it can, the port injectors other job is keeping the back sides of the valves and the valve seats clean. Gas is a solvent and does well in that role with carbon build up.
    In simpler words, the 2GR has minimal carbon issues when maintained the way it’s supposed to be.
    1933beer[OP] likes this.
  8. Sep 29, 2022 at 11:06 AM
    #48
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If I were to do it again I would start with a 1000 mile initial engine oil change. For the stuff in there my feelings are 5000 miles is too long. Add both differentials to that as well, perhaps at an initial 5,000 miles. My engine and front differential lab results were not good; normal but not good. Transfer case was good and I have also checked the WS ATF.
  9. Sep 29, 2022 at 11:14 AM
    #49
    1933beer
    Iowa
    none
    Yes i agree they should have done it ia the 6month visit. They said 8k but did it when i broughtit in for year check.
  10. Sep 29, 2022 at 11:43 AM
    #50
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I prefer mib. Stuff works great in small power equipment that sits for months.
  11. Sep 29, 2022 at 12:05 PM
    #51
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I would strongly recommend against an early first oil change. Why? Most manufacturers these days use an assembly lube which is meant to be mixed with the oil which in turn aids break in. Not sure about Toyota, but most manufacturers these days strongly recommend against an early first oil change.
  12. Sep 29, 2022 at 1:50 PM
    #52
    Toycoma2021
    Interesting, I went into the seller dealer somewhere between 500 & 1000 miles before I left their area and they were willing to do it, but didn’t have the time and I went to the 5,000 mile mark before the first oil change. The lab work was not the best. Don’t have access to my computer at the moment to see what that was.
  13. Sep 29, 2022 at 2:47 PM
    #53
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    Even though it kinda runs with should I use this brand of oil or this, change oil at 3000k, etc...
    1. You'll probably never know if it was used or not that any difference took place?
    2. Has it been scientifically proven to do anything from an independent lab?
    3. Pre dyno #'s and post dyno #'s and wear after n hours?
    3. We used BG products assembling auto and race engines. I think it was called BG Assembly Lube. The guy who was a dealer would know exactly. That stuff stuck like glue and we used it to prelube camshaft, rod & main bearings. Was it any better than y product? Who knows. We never had an issue with any engines after startup....
    It is amazing what works and doesn't that wouldn't seem logical. If you race anything and are doing cheat, grey area stuff for advantages, you know what I mean. Example > Does inserting a screen between intake manifold and carb actually work? How big or small do the holes have to be?
    NET: I wouldn't opt for it. :thumbsup:
  14. Sep 29, 2022 at 6:32 PM
    #54
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    nice
    this is like the Guy Version of "I have a boyfriend"
    https://www.youtube.com/shorts/fALqKy3Wjxs
  15. Sep 29, 2022 at 6:33 PM
    #55
    AxisCab
    Dave
    Have I missed what MIB is?
  16. Sep 29, 2022 at 6:50 PM
    #56
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    The fleet I am a mechanic for uses about 8 oz of BG MOA in every oil change and we've had multiple vehicles come in knocking with no oil left in the engine but no engine damage. Fix the leak, install new oil and filter, send it back out into the world.
    I should specify that we don't use MOA for carbon buildup but to protect the engine against the eventuality of drivers ignoring the low oil light and killing the engine.
  17. Sep 29, 2022 at 7:22 PM
    #57
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Pushing some secret sauce on a traditional first oil change is the douchie behavior I would expect to see from some little shithole of a shop like Jippy Lube that is known for forgetting to refill the engine oil or not tightening oil filters. Coming from a factory representative dealership is just incredibly foul. I don't think I could continue to do business with them. It's hard enough trusting them to get things right nowadays but this puts it on a whole new level.
    It's already been said plenty of times in these past responses but our trucks are not known to have carbon build up issues in the valve train nor is it elsewhere unless oil change intervals are done with silly frequencies like the recommended 10k rather than an appropriate 5k. That's where the carbon build up is affecting piston rings and starting the premature excess oil consumption issues that some Toyotas will experience that lead to engine replacements.
    Maybe I'm giving dealers more credit than I should in this respect. I'd steer clear of that shop if at all possible.
  18. Apr 24, 2025 at 9:11 PM
    #58
    Edasuhk
    Edasuhk Member
    Mine's a 2021 Off-Road and I went the TriboTEX route after a buddy swore by it. No regrets—engine runs quieter, especially on highway trips with the camper. Those $20 BG add-ons the dealer tries to upsell? Nah. At under 6k miles, your engine's not even broken in enough to warrant any additive
  19. Apr 24, 2025 at 9:27 PM
    #59
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
