Oil additive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KC65, Nov 30, 2017.
  1. Dec 29, 2017 at 5:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do some work with Blackstone labs, or discuss them with a tribologist and come to your own conclusions.
    My conclusion after doing that is they are not harmful, but not needed. Just another PTBarnum product.
    hiPSI and House Forsaken[QUOTED] like this.
  2. Aug 27, 2018 at 3:38 PM
    Joisey
    Joisey Well-Known Member
    I saw one of those Lucas displays in the auto store, you know, the one with two chambers with two gears in each chamber, one with Lucas and one without. Turn the gears on the Lucas side and the oil/Lucas mix clings to the gears very well. Turn the handle on the plain oil side and the oil drips off the gears almost immediately.
    NOW turn the both set of gears as fast as you can. Maybe 120 rpm if you are fast. The plain oil side still drips off the gears as soon as you stop. The oil/Lucas side is full of foam from the Lucas in the oil.
    The laws of physics teach us that you can compress a liquid very little at very high pressure. You CAN compress a foam. If you can whip foam in the oil/Lucas mix at 120 rpm, and the average engine idles at 500 rpm, what do you think the inside of your engine looks like with Lucas in the oil at 2000 rpm?
    shakerhood, BSFord and oldnorske like this.
  3. Aug 27, 2018 at 4:53 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I volunteer to be in the control group- the one without the Lucas oil treatment.
  4. Aug 27, 2018 at 5:29 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I think you missed a class... take the reciprocal of the bulk modulus and you get k, which is compressibility.
  5. Aug 27, 2018 at 5:54 PM
    Joisey
    And the compressibility of liquids and solids is very small. "The reciprocal of the bulk modulus is called the compressibility of the substance. The amount of compression of solids and liquids is seen to be very small."
    I didn't miss any classes, did you?
  6. Aug 27, 2018 at 6:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not what you said man. Re read your post. And, oil will compress 2% or so at 5,000 psi. Don't sound like much but when you are dealing with those pressures you had better know what you are doing. I do.
  7. Aug 27, 2018 at 6:04 PM
    Joisey
    I'm not talking about 5K of pressure, so why are you? Perhaps 90 pounds of pressure in an auto engine before the bypass kicks in. The point I made was that the foaming oil with the Lucas additive WILL compress because it contains air. NO?
    hiPSI[QUOTED] likes this.
  8. Aug 27, 2018 at 6:09 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    hiPSI likes this.
  9. Aug 27, 2018 at 6:09 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol just messing with you. You are correct, the air will compress and it will be a bad day.
    In my world I design high pressure systems and fluids, along with many other things you wouldn't think about, are definitely compressible.
  10. Aug 27, 2018 at 6:14 PM
    Joisey
    If compressibility were linear, considering 2%@5000 psi would give you a compression of approximately .00036% at 90 psi, unless I have my decimal place incorrect.
  11. Aug 27, 2018 at 6:46 PM
    OnHartung'sRoad
    Teacher, Joisey’s Googling his answers!!! :bananadance:
    inksin and hiPSI like this.
  12. Aug 27, 2018 at 7:31 PM
    Joisey
    Shhhhhh!!!! I'll give you the apple out of my lunch if you don't tell him.
    hiPSI likes this.
  13. Aug 27, 2018 at 7:35 PM
    Bishop84
    Bishop84 Well-Known Member
    taco2010trd likes this.
  14. Aug 27, 2018 at 7:44 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I don't put anything in the oil. Maybe if I had 250,000 on the OD and it was starting to get a little wonky I might through some snake oil in. When I get to 50K miles, I might add some Techron in the gas for a few tank fulls, (don't use Cheveron gas)
  15. Aug 27, 2018 at 7:56 PM
    #35
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    If you look at the additive package of each oil you will see that Supertech oil from walmart is better than even mobil one. I will provide lab test results below for proof, and yes they are done by an independent lab. They are also all in 5w-30 full synthetic.
    Supertech- http://www.pqiamerica.com/March2013PCMO/supertech.htm
    Mobil One- http://www.pqiamerica.com/March2013PCMO/mobil1.htm
    Valvoline-http://www.pqiamerica.com/March2013PCMO/valvolinesyn.htm
    Pennzoil- http://www.pqiamerica.com/June 2014/pennzplatinum.htm
    Castrol- http://www.pqiamerica.com/March2013PCMO/castroledgesyn.htm
    Quaker State- http://www.pqiamerica.com/March2013PCMO/quakerstatesyn.htm
  16. Aug 27, 2018 at 8:10 PM
    #36
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is this a scam? What's with the pop up windows?
  17. Aug 27, 2018 at 8:12 PM
    #37
    757yotas
    Virginia
    2007 TRD Sport
    Negitive, they state you need adobe reader if you are on iphone (like me). Just click cancel a few times and it goes away
  18. Aug 27, 2018 at 8:25 PM
    #38
    Joisey
    The TBN on Supertech is very low.
  19. Aug 27, 2018 at 8:41 PM
    #39
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Again, I have absorbed a lot of information on oils and fluids and synthetics over the years.
    You can have a failure using the wrong viscosity.
    You can have a failure using the wrong OCI.
    You can have a failure using non certified oil.
    But I have never, ever heard of a failure because of a brand of oil used as long as it's a name brand approved oil in the cortect viscosity.
  20. Aug 27, 2018 at 9:14 PM
    #40
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Yep get what's on sale, hell I change mine every 12,500 based on oil analysis
