Oil additives
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redsoxnation, Feb 12, 2009.
  1. Feb 12, 2009 at 8:26 AM
    Redsoxnation
    Redsoxnation [OP] Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    How many use Slick 50 or Dura Lube or Lucas oil additives when they change oil? If you change every 3500 as I do is it worth it? Another question... Can you subsitute 1qt of syn. oil with 4.5 of dino oil as an option? Currently I'm using Castrol GTX 5w-30w religously
  2. Feb 12, 2009 at 8:28 AM
    Snyperx
    Snyperx Seniore Marcos
    I've used Lucas Oil a couple of times in my fuel. Not sure if it did anything. I know general rule is not to use additives in the oil or fuel.
  3. Feb 12, 2009 at 8:30 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    IMO they are just a waste of money. I doubt they would hurt you engine, but your engine doesn't need them. Just continue changing your oil with quality products and it should last for many many miles.
  4. Feb 12, 2009 at 8:31 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I forgot to answer your other question. Yes, synthetic oils will mix with conventional oils.
  5. Feb 12, 2009 at 8:34 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    There's enough additives in today's oil. Most of the stuff is just a marketing ploy to separate you from your money. Just change your oil at the specified intervals and keep your truck properly maintained and you should last at least 200K miles.
    Oh, and about the Lucas additive:
    http://www.bobistheoilguy.com/images/lucas/lucas.htm
  6. Feb 12, 2009 at 8:44 AM
    Redsoxnation
    Pa.
    none yet...
    That's what I thought.. nice demo on lucas btw.. Ok I'm a sucker at times... thanks
  7. Feb 12, 2009 at 8:50 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    No problem, I think we're born suckers until we gather knowledge through time with help from forums such as these.
  8. Jan 14, 2014 at 4:09 PM
    cdz2nutz
    cdz2nutz Member
    05 tacoma
    3" suspension lift & air bags
    How bout 300k ? Yota's are good for it
