Oil and filter question!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Jan 24, 2012.
  1. Jan 24, 2012 at 6:50 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys I chance my oil couple days ago. I always used mobil 1 full synthetic. This time I used amsoil and the engine sounds weird, so tomorrow Im going back with Mobil 1 again. My question is can I used the same oil filter or do I need to exchange the filter as well??
  2. Jan 24, 2012 at 6:52 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You do not need to change the filter if it is brand new. However I don't think the type of oil would have an impact on how your engine sounds.
  3. Jan 24, 2012 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^
  4. Jan 24, 2012 at 6:57 PM
    Hektor
    Texas
    Its weird I start hearing a weird knockin sound just after the oil change. So Im going back to Mobil 1 just for a peace of mind. Also 5w 30 is correct oil weight for our trucks right guys??
  5. Jan 24, 2012 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    10w-30 is better on the first gens.
  6. Jan 24, 2012 at 7:00 PM
    Hektor
    Texas
    Wow really!! I read here that most of the guys used 5w 30
  7. Jan 24, 2012 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In colder climates, maybe. I dont think anyplace in TX would warrant the use of a 5w oil
  8. Jan 24, 2012 at 7:03 PM
    TexasTacoma37
    It's like 50 degrees here right now. You don't consider that a cooler climate?!
  9. Jan 24, 2012 at 7:10 PM
    Hektor
    Texas
    Wow I always used 5w 30
  10. Jan 24, 2012 at 7:11 PM
    TexasTacoma37
    I've used it for 3 years and we're both still alive to talk about it
  11. Jan 24, 2012 at 7:15 PM
    Hektor
    Texas
    True that bro. Well Im going back to Mobil 1 tomorrow.
  12. Jan 24, 2012 at 7:17 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Good one.
    :D
  13. Jan 24, 2012 at 7:19 PM
    Hektor
    Texas
    Do u used 5w 30 in the summer as well???
  14. Jan 24, 2012 at 7:21 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    that's freezing....
  15. Jan 24, 2012 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First gen vs. Second gen. The second gens call for 5w-30, where as the first genners call for a 10w.
  16. Jan 24, 2012 at 7:28 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    The manual specs 5w-30. Some people run 10w-30 if it doesn't get cold. Since the warm temp weight (30) is the same, it doesn't matter what you run in the summer. Only in winter in cold climates does it matter what the winter weight is. Some people even run 0w-30. If you burn a little oil you can run 10w-40. I can go on and on. Needless to say, the reason your engine might be knocking is the superior amsoil formula needs some time to clean and restore lubrication in the engine. I would leave it in. Best oil out there.
  17. Jan 24, 2012 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My first gen said 10w-30 on the cap, but regardless, you make valid points.
  18. Jan 24, 2012 at 7:32 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I think my 96 used 10w-30 but my 03 is 5w-30.
  19. Jan 24, 2012 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine was a '00....:shrug:
  20. Jan 24, 2012 at 7:41 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    IIRC, my '92 Pickup called for 10w-30. (I know - different engine.)
    My '04 Tacoma, OTOH, definitely calls for 5w-30.
