Oil Brand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rwood, Oct 8, 2023.
  1. Oct 8, 2023 at 6:46 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    When I was a young stupid kid, I thought Subarus were made in Australia. Now that's some damn powerful marketing!
    Irons, joeyv141, HondaGM and 2 others like this.
  2. Oct 8, 2023 at 6:48 AM
    WBTaco
    WBTaco To be determined
    West Bend, WI
    2023 TRD Sport DCSB MGM
    None
    Sounds reasonable. I used 5W30 in Subaru’s due to head gasket issues. Those engines burned though the 0W20 faster than you could fill it. I don’t believe the Tacoma v6 have those problems.
    Delta09 and HondaGM like this.
  3. Oct 8, 2023 at 6:48 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Me too! And I thought Crocodile Dundee drove around in one.
  4. Oct 8, 2023 at 6:48 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Me to… then I figured out there a VW in disguise
  5. Oct 8, 2023 at 6:48 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I haven't had a Subaru or Toyota that used any oil between owners manual recommended oil changes. Five Subies and three Toys. Lots of miles.
    What are you doing to your vehicles that causes them to lose oil?
    RIX TUX, terryhutchinson and HondaGM like this.
  6. Oct 8, 2023 at 6:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Since every other change is dealer based, you clearly trust what they use.
    Using 'better' every other change won't improve or fix anything.
    So either find out what's in their bulk containers and use that or just use the proper SAE and viscosity on your changes with whatever is on sale.
    HondaGM likes this.
  7. Oct 8, 2023 at 7:01 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Those headgasket prone Subie's rotted away before head gaskets were a problem around here :laugh:
  8. Oct 8, 2023 at 7:06 AM
    Firn
    Firn Well-Known Member
    White OR
    I'll say my piece again.
    You bought a Toyota at least in part because they are reliable, and are so when you follow the owners manual.
    What problem do you think you are solving?
    Engine failure? I can guarantee that if you use the recommended oil you won't have engine failure from an oil issue.
    Engine wear? Are you worried about those three psi of compression at 300,000 miles?
    Make sure you keep the end goal in sight. What do you gain over running Walmart Supertech?
  9. Oct 8, 2023 at 7:07 AM
    henryp
    Henry
    Montana
    my one subie didn’t burn oil but that was a lease. Found out from my friend that all their returned leased subies get fresh head gaskets before they go on their used car lot.
    my Toyota engine issue was not a burning oil problem. It just gets noisier. Not sure if unique to mobile one but you’ll find several threads in tundra forums 1UR engines getting noisier with certain oil brands (same specs). I just happen to do both engine oil changes (1UR and 2GR) with the same onsale oil from Costco and noticed it right away. Back to the yota stuff and no longer an issue.
  10. Oct 8, 2023 at 7:41 AM
    WBTaco
    West Bend, WI
    None
    Not sure. The 2013 Forester started to use oil around 115,000 miles. Started changing oil at 4,000 vs 5,000 miles. When I switched to 5W30 the oil consumption was much less so I went back to 5,000 changes. I made the assumption it was a head gasket since the boxer engineers were known for that, and there are no noticeable leaks. This has been my daily ride and not only reliable as hell but sure footed as a mountain goat.
    We also have a 2016 Outback with 55,000 that doesn’t use a drop of oil.
    Decided to switch from Forester to Tacoma only because I miss having a pickup and granddaughter needs car for college and work. The Forester will get her around in the Wisconsin winters with confidence.
    Travlr[QUOTED] likes this.
  11. Oct 8, 2023 at 7:51 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    I own a 05 civic and a 08 tacoma, I buy costco Kirkland full synthetic oil when it goes on sale, it was about $3.30 a quart a few months ago, I buy the box of 20 quarts at a time and I've had no issues. Previously I used pennzoil full synthetic when napa would have a sale lined up with the pennzoil rebate but its been a a few years since I've stumbled across that deal of under $3.00 a quart.
  12. Oct 8, 2023 at 8:13 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Havoline OW-20 from Walmart. Comes in a 6QT box, usually under $30. Carries the highest API classification and category. I change at 7,500mi intervals just to split the difference of factory recommendations.
    Not sure why other oil brands haven't changed to 6QT packages. They're super convenient.
    Canadian Caber and Gfenza89 like this.
  13. Oct 8, 2023 at 10:30 AM
    WNYBill
    WNYBill Active Member
    Bill
    Tacoma SR
    Old mechanic once told me not to worry about the brand of oil, just make sure it shows on the dip stick.
    RIX TUX likes this.
  14. Oct 8, 2023 at 10:45 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Wait, an oil thread that mentions Subarus. Am I on NASIOC?
    SH10151 likes this.
  15. Oct 8, 2023 at 10:50 AM
    #35
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    shakerhood likes this.
  16. Oct 8, 2023 at 11:20 AM
    #36
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    I don't know what I'm going to do today. It's going to get hot again. I just watched Mission Battle of the Baggers. It was a wet race and not as exciting as the dry races. They were actually sliding less in the wet.
    I guess I'll start planning on date rape night with the wife. Got to decide where to go eat. I've been craving some sashimi which she don't feed me anymore. She's not into sushi but likes anyone of the teriyaki dinners. Ribs or steak sounds good too. So hard to decide and I really don't like to have to wait long.
  17. Oct 8, 2023 at 11:29 AM
    #37
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It's like TW was getting along too well, for too long, so we launched this shit-missile.
    henryp likes this.
  18. Oct 8, 2023 at 11:38 AM
    #38
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This is all you need ^
  19. Oct 8, 2023 at 11:40 AM
    #39
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Jeeps creepers... I use basically whatever I feel like. But usually Amsoil or Penzoil. Average day is 5w-30, winter time is 0w30 and, summer on long trips/ if i'm planning to tow alot then 40wt oil. I only really stopped using 0w20 because I didn't like how loud the engine was after a long highway drive. Around town only though I would go back to 0w20 year round. Again any brand really.
    It's not "required" here but I still tend to look for the dexos1 spec as a minimum when my favourite brands can't be had
  20. Oct 8, 2023 at 11:43 AM
    #40
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I got Toyota Full Syn 0w-20 from my dealer for less than $7 / qt. Not sure if they have other weights.
    Otherwise I buy cases or 5gal jugs of Napa Full Synthetic when it's on sale. And I run it 5,000-10,000
