Oil brand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TXRailroads73, Jul 19, 2025 at 9:02 AM.
  1. Jul 19, 2025 at 9:02 AM
    TXRailroads73
    TXRailroads73 [OP] RÖCKIN'ROLLIN',BEER,YOTAS,MAX/GEMMA
    Adam
    The Lone Star State, RGV, TEXAS
    '23 TRD PRO
    None all stock
    Hello all, new to the Taco group, recently purchased a used, new to me '23 Taco Pro with 31150 on the odometer, I know the oil is 0W20, but for the members on here, do you guys have a particular brand you that you like or you guys buy what's on sale? So many brands on the market, I had a '14 Tundra that I used Mobil1
    So what say the community????
  2. Jul 19, 2025 at 9:05 AM
    bwise
    bwise Well-Known Member
    Penzoil Ultra Platinum is what I use. Project Farm has a vid comparing motor oils and this came second to Amsoil. Honestly though any big name brand will work just be sure to change it every 3-5k miles. That’s the most important thing
  3. Jul 19, 2025 at 9:11 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I concur with the above post. The brand is moot, but every 5,000 miles is pennies on the dollar in the long run.
    I did my first at 3,000.
    Then at 5,000.
    Now every 5,000 ( and rotate tires ) religiously. It's a nice round number to remember too.
  4. Jul 19, 2025 at 9:18 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What ever brand that gets poured in every 5k will work.
    Congrats on the new truck.
  5. Jul 19, 2025 at 9:19 AM
    Bishop84
    Bishop84 Well-Known Member
    Whatever 0W20 is on sale. 2GRs can run on used cooking oil.
  6. Jul 19, 2025 at 9:26 AM
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    Super Tech oil from Wal Mart is pretty good priced oil. I haven't read anything bad about it either from folks online. Everyone seems to say good things about it, even Project Farm on YouTube.
  7. Jul 19, 2025 at 9:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Kirkland, Super Tech, whatever. As long as it's the correct spec it's fine.
  8. Jul 19, 2025 at 9:45 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Since you are new to this vehicle I’d say your first oil change will be the real learning experience. Well not the oil but the filter replacement. As others have opined most any oil will do. Since you already know it and feel fine with it stick with the Mobil1 and use the Toyota filter - they are cheap and even available at Walmart.
    That should start some discussion that is found in many other threads.
    I don’t remember the name of the manufacturer but there is a kit with a funnel, oil filter wrench, oil filter drain all together that I would recommend. Also an oil pan drain valve too is nice. Stahlbus is my preference for the oil pan drain for the included very flexible drain hose and the method of attachment of said hose.
  9. Jul 19, 2025 at 9:52 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    I've done the Tundra oil change, its just that this Taco has the skid plate, saw some youtube videos on it, it doesn't need an oil change now as its fresh now, I'm gonna add the fumoto valve to it and I ordered the motovix oil change kit as well
    Toycoma2021[QUOTED] likes this.
  10. Jul 19, 2025 at 11:45 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  11. Jul 19, 2025 at 11:48 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Oil change frequency is just as important… do it every 5k miles despite Toyota saying every 10k. Cheap insurance.
  12. Jul 19, 2025 at 12:08 PM
    Big Cole
    Big Cole Well-Known Member
    I use the Wal Mart branded synthetic and change every 5,000 miles.
  13. Jul 19, 2025 at 12:19 PM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Anyone with the trd skid plate?, does it have to be removed to put the fumoto valve on??? Also do the sell the aluminum oil filter housing to get rid of the stock plastic one????
  14. Jul 19, 2025 at 12:26 PM
    BillyE
    BillyE Well-Known Member
    It would be a challenge to find an oil that you couldn’t run. I’d wager that you could use ANY oil available at Walmart, in any grade, and you couldn’t tell the difference unless you crank it at low temps (<10F)
  15. Jul 19, 2025 at 12:42 PM
    Toycoma2021
    My Stahlbus only needed a deep socket, have no experience with the Fumoto. It looks like an open end would be best for that installation. Hint, for the best visibility above the skid plate turn the wheels in one direction and move your head up into the wheel well.
    If treated well (not over torqued) either the plastic or aluminum filter housing's are fine. I initially used both, alternating between the two, having one ready with a new filter after removing the other. I’ve since gone to two aluminum housings as I can see it in the dark much better.
  16. Jul 19, 2025 at 2:23 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I like Mobile 1 with an OEM oil filter.
  17. Jul 19, 2025 at 3:30 PM
    e_engstro
    Eric
    Arizona
    Yes, there is an aluminum option for the filter housing. Amazon for the win....
    https://www.amazon.com/Assembly-156...2&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY
  18. Jul 19, 2025 at 3:33 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, you are going to get a thousand different answers with this thread. FWIW I use Mobil 1 with OEM Filter.
    TacoSR523 likes this.
  19. Jul 19, 2025 at 3:50 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Clean oil of the correct grade is more important than brand.
    Any name brand meeting specifications is fine, OEM filters are well priced at the local dealer.
    I prefer to change at 5,000 mile intervals.
  20. Jul 19, 2025 at 3:52 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Honest question, please no flaming. Just asking. With synthetics claiming 15-20k intervals (I would never go that many miles personally) why are some saying change at 5k? Yeah I understand cheap insurance but besides that.
