Oil Burner
Discussion in 'Performance and Tuning' started by Gatorstaco, Sep 22, 2014.
  1. Sep 22, 2014 at 4:48 PM
    Gatorstaco
    Gatorstaco [OP] Well-Known Member
    Gaetan ( Gator)
    ontario
    14 X-Runner
    AFE Cold air, Magnaflow exhaust, all AMS oil, tonneau cover, and Cap hitch, extra LED light(back). LED fog lights. Summer wheels Scan gauge II. Sirius radio
    Has anyone ever had any issue with excessive oil consumption. My X-Runner is using a lot of oil, only have 97000 km. Never had any issue for the pass 4 years and all of a sudden it burning oil. No smoke but black tail pipe, plugs had a thick deposit on them. Check compression, 205 to 210 on all 6. It idles at 700 rpm and smooth, acceleration is good, mpg is bad as usual. Might be time for a V8 swap?
  2. Sep 22, 2014 at 4:58 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Like how often are u a quart low? Ive got 184... MILES on mine and never use a drop. Are u sure ur not just running rich (obviously if ur low on oil thats most likely not the case but since i dunno how much u using just throwing out other possibilities)
  3. Sep 22, 2014 at 5:13 PM
    Gatorstaco
    Gaetan ( Gator)
    ontario
    14 X-Runner
    1 quart for a tank of gas
  4. Sep 22, 2014 at 5:28 PM
    yota243
    E.J.
    north Alabama
    Holy crap dude. Sorry i should have ask liters i guess but u figured it out it seems. I got nothing, but u could put an oil catch can on and atleast not be burning it. Not an expert but since it has to be coming out of ur pcv if ur not leaving puddles everywhere i guess u kinda have a starting point.
  5. Sep 22, 2014 at 7:23 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Might want to do a leakdown test instead. That should pin point the actual problem in the cylinder head. Probably one of the valves seals are going bad.
  6. Dec 29, 2014 at 2:58 PM
    Gatorstaco
    Gaetan ( Gator)
    ontario
    14 X-Runner
    Been checking that engine and talk to different mechanics. Did install a oil catch can and no oil going by the good PCV valve. Did an engine flush as recommended from Toyota and put fresh oil in with filter. Will check oil level at next fill up. If no change, time to check the valve guide seals. Only place were the oil can get by. Will go and get a price $$$$$ at Toyota for that job.
  7. Dec 30, 2014 at 3:47 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    or bad piston rings. its common on camry for them to burn oil from bad rings
  8. Dec 30, 2014 at 4:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not really. A stuck oil control ring will allow both oil consumption and not show on a compression test. It's why Toyota recommends the 'flushing', in an attempt to free the ring(s)
    If a leakdown test proves its in the head, please don't waste your $ at the dealer.
    If you don't want to refresh them yourself, at least remove them and take them to a machine shop to be done for you. (90% odds what a dealership will do)
    Or buy fully reconditioned heads from a third party (like http://www.cylinder-heads.com/ (no affiliation)) and bolt them on yourself. (10% chance what a dealership will do)
    If you are wrench-phobic, find an independent mechanic to do the work.
    Anything but a dealership for non warranty major work.
