Oil Cap Left Off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gduarte4, Jan 23, 2017.
  1. Jan 23, 2017 at 7:38 AM
    gduarte4
    gduarte4 [OP] Member
    Guy
    I had my first oil change this last week on my 2017 Tacoma TRD Sports. I took it to my trusted mechanic I have had for over 20 years. They used Mobil 1 synthetic and Toyota oil filter. I drove it to work over 40 miles and when I got to work I had a check engine light. Took it in after work, the owner opened the hood, and to our amazement, there was the oil cap sitting on the battery.
    It had been raining that day and when we opened the hood the engine compartment was dry. No water. He tightened the oil cap and told me not to worry. He said the computer thought it was a vacuum leak because air was getting in the oil tube. He reset the computer turning off the engine light and it has been running fine with no warning lights ever sense.
    Even though the engine compartment was dry, I'm still a little worried that water got in the tube. I had a nightmare after I went to bed! HA! Do you think I'm overreacting because I'm a new Tacoma owner? My mechanic gave me a new out of the box K&N air cleaner as an apology. I guess we all make mistakes but I'm gonna back-check their work from now on. Do you think my truck is okay?
  2. Jan 23, 2017 at 7:40 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    If you put your cap back on and the engine light is off and the truck is running fine I'm sure the truck is unharmed!
    Kilokato likes this.
  3. Jan 23, 2017 at 7:41 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Did the light turn off?
    (Yes) Everything is ok.
    (No) Take it to Toyota to service, if charged, send your trusty mechanic the bill
    Why did you not just take it to Toyota in the first place? Did you not get any services included on your purchase?
  4. Jan 23, 2017 at 7:42 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    no issue at all. if you are worried check the oil on the dipstick.
    Kilokato and shakerhood like this.
  5. Jan 23, 2017 at 7:44 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Take it for a 60 minute highway run. You will get the oil up to its maximum temperature and any water in the oil will evaporate.
    Kilokato, su.b.rat, Bannerman and 2 others like this.
  6. Jan 23, 2017 at 7:44 AM
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    Even if some water got in (it didn't), it would have cooked out in a 40 mile drive.
    Kilokato, CusterFan and ZachMX like this.
  7. Jan 23, 2017 at 7:47 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    He gave you a return business gift.
    You will be back when the k&n fouls up your maf sensor
    Tacowin1013, smitty99, over60 and 5 others like this.
  8. Jan 23, 2017 at 7:50 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    As above. If a little water got in it'll cook off with a good long drive. If a lot of water got in you'll see signs of it on the dipstick. If neither of these sooth your nervousness, have the oil changed again. Any water still in the system will be at the bottom of the sump.
  9. Jan 23, 2017 at 7:50 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    At the very least, your mechanic should have offered to change the oil and filter right away, just to eliminate any chance of water lowering the viscosity of the oil and damaging the engine.
    shakerhood and Caltech90 like this.
  10. Jan 23, 2017 at 7:51 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    If you are really concerned. Send a oil sample for analysis.
  11. Jan 23, 2017 at 7:53 AM
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    30 years ago, I forgot to put the oil filler cap on my 76 Celica and it was spitting oil out of the valve cover all over the engine. When I got home, I saw a flickering light under the car which turned out to be flames from the oil on the motor and ehaust manifold. That's when it's time to worry :bananadead:
    Worst part was when I opened the hood and it drew air from underneath...:anonymous: Ahhh...To be 16 again!
    WaldoJPL, over60 and CusterFan like this.
  12. Jan 23, 2017 at 7:56 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    What a classic!
  13. Jan 23, 2017 at 8:01 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    This + a refund!
  14. Jan 23, 2017 at 8:11 AM
    gduarte4
    Guy
    Thanks for everyone's reply! I saw the engine compartment and it was dry. The plastic engine cover was dry and the battery was dry. Also the dip-stick was clean and the oil was clear. I was very lucky that the cap didn't pop off the battery and end up on HWY17 in Campbell ca.
  15. Jan 23, 2017 at 8:13 AM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    Actually it was better that it was raining to keep the dust down. Not that too much dust would have got in there anyway.
  16. Jan 23, 2017 at 8:25 AM
    gduarte4
    Guy
    I had real bad experiences with dealerships over the years. One incidence was my wife's car had an oil change at the dealership and they spilled oil everywhere on the plastic engine cover under the engine. there was oil drips on our driveway for weeks. There have been scheduling issues, rude treatment, and such from dealership that I told myself I would never go back. So, this has been the first issue in the 20 years I have had with my mechanic. Thanks for your input! :)
    CusterFan likes this.
  17. Jan 23, 2017 at 11:44 AM
    NiteTaco
    North Alabama
    09 TRD DCSB
    Haha! Funny part was that my Celica burned through about a quart of oil per week (yah...It was driven really hard and smoked like an SOB)! I used to put about a half of a quart in every 2-3 days and it was bound to happen that I eventually forgot to put the cap on one night. Better yet, I didn't realize at first why my car was on fire (couldn't see through the flames and smoke) so I ran inside and grabbed a big bag of salt from the cabinet and threw it all over the motor to put the fire out (wait for it)...........A couple pounds of salt later I realized the oil cap was off and there was a bunch of salt inside the valve cover!!! DOH! o_O
    CusterFan[QUOTED] likes this.
  18. Jan 23, 2017 at 1:05 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    That's funny but I can see how that would happen.
    I work in insurance and I've read a lot of claims that were ultimately caused by temporary lapses in judgement. Some of them were funny.
    I saw one where a guy was driving through his front hard and ran his truck into a bathtub. No surprise, that one was from Arkansas.
    I saw one where a guy's motorcycle caught on fire and he didn't have anything on hand to put it out so he pushed the entire motorcycle into a pond.
    I saw one where a male driver and a female passenger both had head injuries from the steering wheel. They were surprisingly honest when asked how that was possible.
  19. Jan 23, 2017 at 1:16 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    I used transmission fluid for brake fluid one time.....Not too good! :anonymous:
  20. Jan 23, 2017 at 2:05 PM
    gpb
    Atlanta
    Reminders of The World According to Garp... :eek: :bananadead:
