Oil cap vibrating off???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco4you2, Oct 24, 2022.
  1. Oct 24, 2022 at 1:55 PM
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    I bet its a reoccurring issue at THAT dealership due to the dumbfvck they hired to do the quicky oil changes
  2. Oct 24, 2022 at 2:01 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    You might want to check the oil filter too...
  3. Oct 24, 2022 at 2:02 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup that's total BS, they forgot to put it on. If your engine shakes that much to vibrate the oil cap off then something is seriously wrong with your engine. Go back & tell em you want a new engine under warranty. :D
    mquibble likes this.
  4. Oct 24, 2022 at 2:10 PM
    DUCKSURF
    DUCKSURF Well-Known Member
    JOE
    Wayne PA
    2017 TACOMA DC SUPER WHITE
    100 percent IMO that the dealer who serviced your truck forgot to put the cap back on. Happened to me not once but twice. I always check the engine bay, lug nut lock adapter and the under side.
  5. Oct 24, 2022 at 2:12 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Strange issue with the oil cap. EDIT--I call BS from the dealership!!!
    I would hand twist the OEM oil cap (on/off) and check it periodically with no issues. (Gives the hood struts usage by checking the engine bay once a week)
    In April of this year, I upgraded the oil cap to a nicer looking one.
    It gets twisted on/off as the OEM oil cap did (which I kept) and has a better grip.
    The engine bay is a work in progress...once I need to replace the battery to one without caps, I can put the battery tie down I bought from a member here.
    RustyGreen and Mastiffsrule like this.
  6. Oct 24, 2022 at 2:18 PM
    Taco4you2
    Taco4you2 [OP] Member
    SR SX
    Lmao yeah I got totally snowed by them but it was hard to argue when you have the whole
    Service team nodding there heads in unison
    I got a free TRD oil cap tho…Radical!
    TacoTime55 likes this.
  7. Oct 24, 2022 at 2:23 PM
    saint277
    saint277 Vigilo Confido
    Nice you came out ahead then.
  8. Oct 24, 2022 at 2:48 PM
    Taco4you2
    SR SX
    Oddly no. I thought the cap was essential to retain oil pressure which is why I thought my
    engine was effed
  9. Oct 24, 2022 at 2:48 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    They were all in on it. ;)
  10. Oct 24, 2022 at 3:05 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Of course. They know who's signature is on they paycheck.
    Taco4you2[OP] likes this.
  11. Oct 24, 2022 at 3:05 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    This is a common problem. Why has no one had this happen to them? Usually when it happens the fog lamps simultaneously eject from the bumper. :pumpkin:
    TacoTrigger16 and Taco4you2[OP] like this.
  12. Nov 12, 2022 at 1:19 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    I was getting ready to see my mechanic.... but I figured I check things out here first.
    Got an oil change ~350 miles ago. Went to check the oil before I left this morning. Something looked odd. Bingo. No oil cap. Swirled my finger down the filler neck... It's dry. No oil on the underside of the hood. Oil on the dipstick is as clean as when it was changed. I haven't driven in the rain. Checked the skid plate. Nope. So I put a ziplock sandwich bag and a rubber band over the opening and went to the auto parts store and bought one. Installed as tight as a hand can tighten it.
    Drove 150 miles. Checked it upon arrival. It was loose, but still present.
    Beats me why... I am thinking about chalking it (like the brownies do to your tires to ensure you've moved your car once every two hours lest you pay a $125 parking tickets) to see if it wiggles itself loose.
    Maybe I am in the twilight zone....
    I shouldn't have to use channel locks to tighten an oil fill cap.
  13. Nov 12, 2022 at 1:32 PM
    Clearwater Bill
    Billy
    Largo Florida
  14. Nov 12, 2022 at 1:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There should be a gasket under the cap. Look and see if it’s there. That gasket does more than keep oil from leaking. It also helps keep the cap tight to the valve cover.
    bulalo likes this.
  15. Nov 12, 2022 at 2:48 PM
    #35
    BurntChickenNugget
    BurntChickenNugget Well-Known Member
    Eric
    2017 Tacoma TRD
    Mabe the reoccurring issue is that their tech's keep forgetting to put the cap on! Lol.
    I've always done my own oil change and never had an issue with the cap coming off. ‍♂️
  16. Nov 29, 2022 at 8:16 PM
    #36
    djMichaelAngel
    djMichaelAngel New Member
    So i had the same thing happened to my oil cap on my 2021, was cleaning my engine and noticed the oil cap missing. truck still under warranty so the only place that serviced my truck is the dealer. I went back to them and they gave me the run around saying that it was impossible for them to not put the cap back on! they said that I must have had my truck serviced somewhere else. they didn't do any thing! I had to but a new cap at the dealer and put it on. no oil was in the engine bay at all tho. later i got an oil change at the same dealer and made sure the cap was on before I left. few weeks later the cap was missing again! I ended up buying a cap at autozone and it's been on there good for a few months now.
  17. Nov 30, 2022 at 3:28 PM
    #37
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I’m sure these people get this complaint a lot though…
  18. Nov 30, 2022 at 3:30 PM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
    I had to use a strap wrench to loosen mine the other day.
    3rd Gen Tacoma Seal Drag Problems.
  19. Nov 30, 2022 at 3:37 PM
    #39
    Bishop84
    Bishop84 Well-Known Member
    I can't shut a hood without checking the oil fill cap.
    I left one off in 2006 on my own damn car and it sprayed oil everywhere.
    turbosnail likes this.
  20. Dec 1, 2022 at 11:04 AM
    #40
    ULURU
    With every other vehicle I've owned, the oil filler cap required a "push to turn" seat. It had to be depressed somewhat in order to loosen it.
    My Tacoma is the fist vehicle I've owned that had a filler cap with straight or tapered pipe threads on it that relied of straight friction for securing it in place...
    If the technicians don't put it on super-tight, it will wiggle off...
