oil capacity
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spyshot, Feb 11, 2010.
  1. Feb 11, 2010 at 1:50 PM
    spyshot
    spyshot [OP] Well-Known Member
    Dayton Ohio
    09 TDR OFFRoad
    i have a 09 trd off road with 4.0L v6. what is the correct oil capacity? the manual is very confusing but i understood it to say 5.5qts. i called my local dealer and they also say 5.5qts. so i put in 5.5qts. the dipstick is reading really high. an inch or two above the top dot. what's the deal?
    i checked it after the truck ran for 2 minutes and then sat for an hour.
    adam
  2. Feb 11, 2010 at 1:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
  3. Feb 11, 2010 at 1:58 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Having the oil filter on top takes a little more oil, but My TRD OR takes 5 qts exactly.
    Like the stick says "do not overfill":D
  4. Feb 11, 2010 at 2:00 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    The dipstick can sometimes be hard to read, plus it can smear oil when you take it out and it makes it look like there is more than actual amount. Try taking out the dip stick, then wipe it off. Put back in and take out to check again. That sounds kinda dirty lol.
    Anyways......after engine is warmed up, and then turned off. You should only have to wait about 3-4 minutes before checking. And make sure you check the oil on level ground. Hope that helps, and that does sound like the right amount. Maybe your running into the problem up above. Or you put too much in.
  5. Jun 15, 2011 at 8:15 AM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    no. i spoke to a tech at toyota and he advised me to use the dipstick at the proper amount, not the manual. if the oil is too full, (i'm told) that can lead to sloshing which will aerate the oil and it will loose it's lubrication properties.
  6. Jun 15, 2011 at 7:55 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    You would think Toyota would get this dipstick vs owners manual oil capacity thing straitened out. In my case (2.7L four banger) the dealer's work order shows 6 QTs with filter and the dipstick is on the full mark.
  7. Jun 15, 2011 at 8:09 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    On my 4.0L V6 I use 5.5qts with new filter. The dip stick is a pita but if you take a file and etch it in a "X" pattern between the marks it's easier to read. I've get the best readings after letting the truck sit over night. 5.5qts shows up even with the full mark on the dip stick.
  8. Jun 16, 2011 at 10:42 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    I usually put 5.5 quarts even though it reads high on the dipstick.
