Oil catch can, anyone running one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RockfishTaco, Dec 27, 2022.
  1. Dec 28, 2022 at 9:15 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    With what? What are you trying to achieve? It’s not going to prolong the life of your engine.
    Raylo likes this.
  2. Dec 28, 2022 at 9:29 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    https://www.tacomaworld.com/threads...x-power-and-reliability.777293/#post-27785570
    When this guy talks I try to listen. He knows a thing or two about our trucks. Granted this is from the 4banger thread but all the same for long-term reliability.
    I'm close to 250k. Certainly would keep things cleaner than without. Maybe i don't want to burn off water and oil if short money can prevent it.
    I always have plenty of time while the fumoto drains so no problem emptying on the regular.
    Also they cost less than $50 and an hour of my time.
  3. Dec 28, 2022 at 9:36 AM
    Firn
    Firn Well-Known Member
    White OR
    Dodge 5.7 hemi owners would disagree. Some variants of that engine created enough oil vapor it would literally puddle in the intake manifold.
    Some tuners were even observing reduced timing since oil has a lower octane than gasoline.
    Torspd likes this.
  4. Dec 28, 2022 at 9:36 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I think most of the guys that have them installed offroad hard and climb really steep hills. If you get on a long enough and steep enough climb they help prevent motors stalling or blowing black smoke.
  5. Dec 28, 2022 at 9:42 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Catch cans are like the "miracle" supplements you see advertised on TV and use the same marketing and social media strategy. They say they do great things, then below in the extra fine print say "results not typical". Lots of anecdotes from who knows who. Zero official testing to show safety and effectiveness for a given condition. But they don't cost much and don't waste too much of your time, so people say what the heck, why not? If that's you, then go for it.
    pahaf and DVexile like this.
  6. Dec 28, 2022 at 9:53 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    My 4-banger is 8 years old with over 120k miles and doesn’t use or lose a quart between changes so I see no need to catch what little blow by might exist and prevent it from going elsewhere. If you go through oil at a high rate there’s a chance this could help prevent other issues but it won’t correct that one.
  7. Dec 28, 2022 at 9:53 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Well... thats dodge for ya.
    AngryChair1983, DVexile and winkel like this.
  8. Dec 28, 2022 at 5:43 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    You would not get any actual benefit from an oil catch can. They were made for GDI engines due to carbon build up as fuel isn't injected through the ports. Our tacoma's for Gen 2 are port injected for both the 4 cylinder and V6 so the injectors spraying fuel will dissolve any carbon build up on the valves. The 3rd Gen V6 tacoma is GDI so an oil catch can is useful for it but not for 2015 and below. Save your money for something else. If you are losing oil I would see if your tacoma is burning oil or leaking from somewhere.
  9. Dec 28, 2022 at 5:52 PM
    Firn
    White OR
    Catch cans have been used for a LONG LONG time before gdi.
    Reggie4x4 likes this.
  10. Dec 29, 2022 at 10:57 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Curious but relevant, how many miles on the engine? Have you ever replaced or verified that the PCV valve is functioning correctly, especially during cold starts.
    If the valve is sticking when cold, your blowby you suspect may be a result of the crankcase getting slightly pressurized, and forcing the oil more easily into the top end.
    The catch can acts more as a trap, to lessen or prevent oil being drawn into the intake plenum, where it should ultimately be consumed by combustion. Adding a catch can in your situation to resolve this semi intermittent oil consumption seems a bit moot. I would try a new PCV valve or clean the one you currently have, and verify proper operation of the valve.
    Sterling_vH111 likes this.
  11. Dec 30, 2022 at 3:32 PM
    TacoTuesday1
    SD CA
    Exactly. That is a Proper system. Which costs more.
    One thing you can do to mimic that, is install a Mann ProVent 200, tap house routing drain back, with an in-line one way fluid valve, and their filters are replaceable.
    But that setup is like $300+ vs. screwing in a $30 Pepsi Can from Autozone which offers none of the above functions
  12. Dec 30, 2022 at 8:15 PM
    AZ_TACO
    AZ_TACO Well-Known Member
    2009 PreRunner TRD OR
    Toytec Boss 2.5” Front Toytec Boss 2” Rear SPC UCAs CMC Black Rhino Warlords BFG KO2s aFe Wet EA Filter Rigid D Series Pro
    My pops runs one, on his ‘95 Exploder :rofl:
  13. Dec 30, 2022 at 8:27 PM
    TacoTuesday1
    SD CA
    If you are local I would probably trade you mine for your hoses to revert to stock
    to prevent running into issues with smog stations complaining anything on the truck deviates from the norm and does not have the magical Toyota emblem on it
    apparently collecting a small quantity of water and oil to recycle at a later date, worsens the emissions of these extremely efficient trucks
    nd4spdbh likes this.
  14. Dec 30, 2022 at 8:33 PM
    Firn
    White OR
    If his 95 Explorer is still running then they MUST work.
  15. Dec 30, 2022 at 8:49 PM
    #35
    AZ_TACO
    HA! It sure is, I think ~450k now. I’m starting to think he’s just got an in with the big man
  16. Jan 3, 2023 at 5:25 AM
    #36
    RockfishTaco
    RockfishTaco [OP] Well-Known Member
    Nate
    Massachusetts
    I'll take a look into this. 125k now but at the time of that oil change had about 110k.
