Oil catch can options for 2019 3.5 L
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Huskador, Jun 30, 2020.
  1. May 4, 2022 at 8:03 AM
    #161
    eurowner
    eurowner Duke Sky
    Scoty
    "The PCV catch can kit runs inline between the PCV valve and the intake pipe. When the intake manifold pressure is close to or greater than atmospheric pressure, the PCV "check" valves close and, thus, this hoses experience no flow. Conversely, the PCV hoses will experience "metered" vacuum when the engine is idling, steady state cruising, and decelerating. This would normally draw unwanted crankcase vapor, unspent fuel, and oil sludge into the intake manifold immediately after a high load run.
    The PCV catch can promotes clean filtered air back into the intake manifold."
    "The CCV catch can mounts to threaded bosses in the engine bay on the inner fender with the provided supplementary bracket. To retain factory functionality, the CCV catch can runs inline between the crankcase vent (CCV) port and the intake pipe. At low loads, it experiences atmospheric pressure. However, when the engine is at high load (WOT), the line will experience high flow from the crankcase into the intake system. This would normally lead to oil and sludge accumulation in the air filter intake pipe. The CCV catch can captures this and promotes clean filtered air back into the intake.
    The CCV catch can kit does NOT address blow-by from the PCV side of the crankcase."
    http://www.radiumauto.com/Blog/Post/Catch-Cans-101-102
    /\ Says 8oz and shows Diagrams! :eek:
  2. May 4, 2022 at 8:25 AM
    #162
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Been interesting reading everyone’s experience with catch cans and how full they get. I installed one as a bandaid for when off-roading but after 10k miles on the first change I had maybe a teaspoon of oil…
    Big tall dave, Junkhead and eurowner like this.
  3. May 4, 2022 at 8:30 AM
    #163
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    eurowner likes this.
  4. May 4, 2022 at 8:59 AM
    #164
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Thanks for the information and link.
    My MAIN question remains: For the 3.5L how much gunk have people actually caught on the CCV side?
  5. May 4, 2022 at 9:01 AM
    #165
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I definitely get more than that with JLT. Every 5K or so, maybe near 2-3 oz or so.
  6. May 4, 2022 at 9:03 AM
    #166
    eurowner
    eurowner Duke Sky
    Scoty
    :thumbsup:
    Considering that Radium is the first company to make a CCV side system it is very new. Have you asked Radium?
    Pablo8[QUOTED] likes this.
  7. May 4, 2022 at 9:03 AM
    #167
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    I don't think there has been a CCV option until now. I wouldn't image it would be a ton, or even more than the PCV side, based off of what Radium is stating on their website. It looks like on the CCV side, it is most likely to accumulate liquid/oil under WOT. I am also curious under normal, daily driving circumstances how effective the CCV catch can would be.
  8. May 4, 2022 at 9:05 AM
    #168
    JoeCOVA
    Joe
    Colorado Springs
    ? Which do you have the JLT Catch can only holds 3 oz
  9. May 4, 2022 at 9:05 AM
    #169
    eurowner
    eurowner Duke Sky
    Scoty
    I will be updating when I get my Radium "too expensive non-Areoquip hose'd dual can system" installed, for sure!
    Pablo8 and JackJoachim[QUOTED] like this.
  10. May 4, 2022 at 9:14 AM
    #170
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Well shit I thought it held 4oz and usually 50-75% full of bong juice. Edited my post. Thanks.
  11. May 4, 2022 at 9:15 AM
    #171
    eurowner
    eurowner Duke Sky
    Scoty
    I remember talking to you about that situation a little bit ago. Did J&L ever get back to you about it?
    S&B Bought out JLT performance intake and the people that invented the JLT catch can systems are now J&L OSC
    bulalo[QUOTED] and Pablo8 like this.
  12. May 4, 2022 at 9:15 AM
    #172
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Good answers.............have not asked Radium. Will wait for early adopters to report back.
    eurowner[QUOTED] likes this.
  13. May 4, 2022 at 9:16 AM
    #173
    JoeCOVA
    Joe
    Colorado Springs
    I'm going to check mine today, I think I have about 3k on it and recently did some offroading in Moab so curious whats in there now.
  14. May 4, 2022 at 9:16 AM
    #174
    eurowner
    eurowner Duke Sky
    Scoty
    I try my best.
    I will get back with pictures. It has shipped and will be in my hands this Friday!
  15. May 4, 2022 at 11:08 AM
    #175
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    I did not contact them . Just sold it as the ticking sound is really annoying me. Still looking for a can that doesn’t amplify the engine noise (ticking).
    Thanks for the link. Looks like j&L can and JLT are similar
  16. May 4, 2022 at 11:10 AM
    #176
    JoeCOVA
    Joe
    Colorado Springs
    So in 2k miles and Moab off-roading my catch can collected about 10ml of oil. Which seems about normal for me but still a small amount compared to what I am hearing.
    Big tall dave and eurowner like this.
  17. May 4, 2022 at 11:10 AM
    #177
    eurowner
    eurowner Duke Sky
    Scoty
    I'll let you know how the Radium setup works for me.
    bulalo[QUOTED] likes this.
  18. May 4, 2022 at 11:16 AM
    #178
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Thanks. The radium set up looks very promising. Looks legit. I don’t mind the price as long as it doesn’t amplify the ticking sound . Pls keep us posted.
  19. May 4, 2022 at 11:18 AM
    #179
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Oh man - those look CLEAN! I have the J&L single and like how it mounts to that unused bolt hole on the driver's side of the block near the firewall. My only gripe with this dual can setup is where it mounts as I am looking to put my electrical accessories there (relays, accessory fuse block, etc.). Pics have it driver's side near the firewall where I have plans, although it looks like you can mount the brackets anywhere. Since I have a sport I'd probably put them up on the passenger side firewall above the ABS valving.
    uploadadventure likes this.
  20. May 4, 2022 at 11:58 AM
    #180
    JackJoachim
    Jack
    North MS/Memphis
    I am sure you could mount them anywhere. Also you could really use any catch can(s) you wanted as well.
    mic_sierra[QUOTED] likes this.
