oil catch can our 3rd gens anyone?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shotgunbilly420, Apr 30, 2019.
  1. Mar 7, 2020 at 7:56 PM
    #41
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Absolutely nothing ... (said in best Edwin Starr voice)
  2. Mar 7, 2020 at 8:02 PM
    #42
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    SEAFOAM!!!
    Pour it in the intake from the PCV valve and watch it smoke!
    nomnomtaco likes this.
  3. Mar 7, 2020 at 8:50 PM
    #43
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Nobody gives a fuck.
  4. Mar 7, 2020 at 8:50 PM
    #44
    stun gun
    Aaronski
    Tacomas.
    Good gawd y’all
    HUHHHHHHH
  5. Mar 7, 2020 at 10:20 PM
    #45
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    Do whatever the hell you want to with your truck. If you want to catch oil go right ahead. Gotta catch em' all.
    Anton338 and stun gun like this.
  6. Mar 21, 2021 at 5:08 AM
    #46
    shotgunbilly420
    shotgunbilly420 [OP] OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Well for a update my jtl 3.0 catch can works great
    Drain every 3,000 mi it catches alot of crap
  7. Mar 21, 2021 at 7:23 AM
    #47
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    It goes like this...to each their own!, I got one...it's my vehicle and it's my $30 insurance. Sure you could spend $150 or more...we all spend our own money...
  8. Mar 21, 2021 at 7:24 AM
    #48
    shotgunbilly420
    If you would see the amount of tan creamy crap that this catches during the winter you would want one too . I'm all about keeping the internals clean and not diluting my gas in my truck . Ok ta cheap insurance and if they didn't work why the hell is there so many online
  9. Mar 21, 2021 at 7:46 AM
    #49
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    Maybe the same reason there is a trd intake... they look pretty and people buy them?
    Speedbird and NotYourDAD like this.
  10. Mar 21, 2021 at 8:50 AM
    #50
    k20pham
    k20pham Well-Known Member
    KP
    2019 taco
    Initially, wasn’t this recommended for the smoking on incline troubles? Does anyone here wheel and have their two cents to throw in?
    Unless you do plan to wheel at those angles, your port injectors should clean your intake valves enough to prevent any carbon buildup.
  11. Mar 21, 2021 at 8:51 AM
    #51
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Why? Because so many people just want the little dopamine they get when they buy a new toy. There are so many do-dads available that don't increase function.
    As far as the milky oily stuff in a catch can, every time you shut your engine down, it cools and sucks moist air in. When you crank it up, and it gets hot, it cooks back out and goes through the engine and out the exhaust....
    When you install a catch can, it cools it back down and collects it..... with oil vapors.... making that milky mess.
    Catch cans are good in the right application. For 99.99999% of Tacoma owners, it's added risk (if you don't empty it) and hassle for something that isn't necessary.
    Now if you go up extreme hills, it might help keep a big slug of oil from getting sucked into the intake.... maybe.
    Speedfreak and RedWings44 like this.
  12. Mar 21, 2021 at 8:54 AM
    #52
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    They're necessary for direct injected engines in order to keep buildup from occurring on the valves. However, the Tacoma uses direct and port injection making this kind of redundant. It isn't really going to hurt anything, but it isn't as big of a benefit as everyone is making it out to be either.
  13. Mar 21, 2021 at 9:14 AM
    #53
    NotYourDAD
    NotYourDAD Member
    13 taco TRD dcsb
    total chaos mid uca, 285/70/17 w-12 offset, body mount chop, T/C bed stiffener, Leer shell,
    so being it the service industry i have the pleasure of draining these pieces of "equipment" ..... many times the vehicles come in with the valve open and sucking dirty air, mess everywhere or its so over full due to lack of maintenance between services. i absolutely believe they catch oil, but it is not necessary for your normal N/A vehicles. T/C and S/C vehicle where you have higher crankcase pressures and the expelling of more then just blow by gasses, a catch case is a good idea [with a proper maintenance schedule]
    catch cases are like face masks, you either believe they work or you don't but at the end of the day its your call.
  14. Mar 21, 2021 at 9:19 AM
    #54
    Sungod
    Sungod Well-Known Member
    St Augustine
    If you have that kind of problem after 35k, I think you have something going on that is more serious than what your little catch can will fix.
    NotYourDAD likes this.
  15. Mar 21, 2021 at 9:27 AM
    #55
    skitso1080
    skitso1080 Member
    2018 Tacoma TRD Sport 4x4
    Squash Air Freshner
    There have been plenty of Toyota engines that have gone over 500,000 miles without a catch can. The fuel system on the 3g taco is pretty nice as it is direct and port injected. Even with the oil vapor coming in, the port injection helps address that.
    NotYourDAD and RedWings44 like this.
  16. Mar 21, 2021 at 9:33 AM
    #56
    shotgunbilly420
    Well for a peace of mind and for the life of my truck I will keep it plus stimulus paid for it not my hard earned money . Lookout here comes the insults on our tax money
  17. Mar 21, 2021 at 9:37 AM
    #57
    shotgunbilly420
    I drain and clean collector every 3k clean the lil filter every 10k as recommend by manufacturer it's part of my maintenance program I'm ocd adhd rather it is or isn't smoke and mirrors it does collect gunk and crap that I don't want in my motor so yeah I'm really thorough with my truck I treat my truck as if it was the president of the good ole usa and I'm the presidents doctor best of best
  18. Mar 21, 2021 at 9:39 AM
    #58
    shotgunbilly420
    You guys gets so angry over a guys particular maintenance regimen
    Skydvrr and RedWings44 like this.
  19. Mar 21, 2021 at 9:52 AM
    #59
    NotYourDAD
    NotYourDAD Member
    13 taco TRD dcsb
    i don't take someones lack of vehicle maintenance personally. I get paid to fix stupid on the daily, and business at the FORD dealer is booming...HAHAHAHAHAHAHAHA fluids in filters at a regular interval based on usage. based in where i live and how i utilize my 13 tacoma i fall within the severe duty, LOF every 5K i choose to replace the diffs and T-Case, trans [6spd] every 50K for the driving i do. fluids and filters are cheaper then major repairs and or getting a tow out of the back counrty
  20. Mar 21, 2021 at 9:53 AM
    #60
    RedWings44
    Michigan
    You should see what happens when you tell people you change oil every 5k miles instead of the 10k Toyota says.
    D.A.S. Taco, Skydvrr and NotYourDAD like this.
