Oil catch can
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 25, 2014.
  1. Dec 23, 2014 at 5:21 PM
    #361
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Thought this is a pretty good article on painting stainless steel: http://www.bssa.org.uk/topics.php?article=119
    Hope it helps.
  2. Dec 23, 2014 at 7:12 PM
    #362
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    haha! I knew I'd get a rash of shit! I'm an old timer, guys, so forgive me for thinking in terms of a carburetors fuel/air mixture washing intake manifolds!
    Fuel injection is a new concept for me, but really, please educate me, what difference if the air intake gets oily? Can you link it to a quantifiable problem?
    All I can see is it actually serves as a Top Oiler, a gadget sold to deliver oil to the valves as exposed to combustion products. A catch can looks purdy, but seriously, isn't this just another gadget designed to lighten your pocket book?
  3. Dec 23, 2014 at 7:18 PM
    #363
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I'm interested to find out! ^
    :pccoffee:
  4. Dec 23, 2014 at 7:22 PM
    #364
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Check the PCV lines periodically. I found out the hard way today. I just drove from colorado to Florida and my can barely had anything in it. The line coming off the outlet side of the motor came loose and blasted nasty oil all over my motor for the past 2,000 miles. Fun stuff.
  5. Dec 23, 2014 at 7:40 PM
    #365
    Lord Helmet
    Nick
    '24 X3 M40i
    Kinda lazy to type out the info: http://oilcatchcan.com/
  6. Dec 23, 2014 at 8:13 PM
    #366
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you not see the picture I posted of the oem BMW catch can. Which also returns the oil back to the crank case? Complements the article which Lord Helmet posted.
  7. Dec 23, 2014 at 9:43 PM
    #367
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    And how many miles of what kind of driving did that take to get that way? And a link or better quality pics would be nice.
    I need to know.:confused:
  8. Dec 23, 2014 at 11:41 PM
    #368
    wanna taco
    alan
    SF Bay Area
    Some systems divert recovered oil to the crankcase, but all gases from all systems are piped to the air intake. Venting to the atmosphere would violate clean air standards
    This explanation (authored by a supplier of catch cans), claims "increased chance" of this and that, but fails to deliver any solid facts
    I saw this picture. It demonstrates an OEM catch can system that diverts recovered oil back to the crankcase of a supercharged engine, apparently a valid reason for having a catch can. Does Toyota offer this option with it's blowers? May be worthy of an inquiry!
    Thank you for that, I rest my case.
  9. Dec 24, 2014 at 6:08 AM
    #369
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You missed the point of my picture. It doesn't matter that it is on a s/c engine or not. The point is that OEM's know about the purpose of catch cans and implement them. That particular style due to the lack of maintenance required by the user. Crawford makes a similar aftermarket one for Subarus. OEM's with only install them when their price point is high enough. It is not a top oiler. It is essentially an oil separator.
    If you were to remover your upper plenum immediately after reading this, you would find oil film all over the intake runners, lower plenum, and intake valves. The engine running is alone what causes the build up because it pulls a vacuum from the valve train, all the way to the oil pan. Fresh air side inlet, is on the intake, post MAF sensor. Outlet is on the driver side valve cover, which is then sucked into the rear of the upper plenum.
    What do you think that oil that goes through the system does? Well, it collects everywhere that it moves through. The intake tract, the valves, the pistons/piston rings, exhaust valves, and cats.
    Ever had an exhaust leak and seen what happens if it leaks onto an exhaust component? It burns and bakes on. Same thing happens on the pistons rings, valves, and cats. Enough of it on the rings and valves, and poor sealing will occur. Poor sealing means loss of compression and more blow by, which amplifies the oil vapor consumption.
  10. Dec 24, 2014 at 6:12 AM
    #370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There have been a few people on XRU to post before and after pictures of their TRD heat exchangers. Nearly looked clean after the catch can install, and the same oil change interval. I specifically remember Coup being one member to post such a picture.
    That oil build up on that exchanger will also decrease its cooling efficiency. As small as it already is, it needs not any thing else to lessen its ability.
  11. Dec 24, 2014 at 9:08 AM
    #371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Dec 24, 2014 at 9:49 AM
    #372
    Lord Helmet
    Nick
    '24 X3 M40i
    Exactly :thumbsup:
  13. Dec 24, 2014 at 9:52 AM
    #373
    Lord Helmet
    Nick
    '24 X3 M40i
    Several sources: not only supplier of catch cans.
    Compliments to:
    Howstuffworks
    Wikipedia
    R-Performance
    Elite Engineering
    University of Maine Science Center
  14. Dec 24, 2014 at 10:41 AM
    #374
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would say that the University of Maine Science Center fills a role as credible. ;)
  15. Dec 24, 2014 at 10:50 AM
    #375
    wanna taco
    alan
    SF Bay Area
    Good discussion. Does anyone know if the supercharger option from Toyota has a catch can? It seems that if other manufacturers (Which ones?) incorporate it, that Toyotas supercharger would also have it.
  16. Dec 24, 2014 at 11:01 AM
    #376
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Bottom line...engines have numerous different filtering components/systems to HELP its efficacy, and to prolong its utmost performance...these ideas were incorporated into the functionality of the engine by research and design engineers who had integral input in its conception, and design...I don't understand the arguement of why not utilize these very components, or Modify with them, to help the longevity, and performance...Just because Taco's don't come fitted with this oil can filtering system, does not negate its potential useful purpose....Put one on and STFU......:D
    #MerryChristmas
  17. Dec 24, 2014 at 11:02 AM
    #377
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    No Can with the S/C' r......
  18. Dec 24, 2014 at 1:09 PM
    #378
    Lord Helmet
    Nick
    '24 X3 M40i
    :rofl:#BuyaOilCatchCanForChristmas
  19. Dec 24, 2014 at 2:30 PM
    #379
    wanna taco
    alan
    SF Bay Area
    I'll get one and install it... But only if one o' youse guys buys me a supercharger for Christmas!
    Merry Christmas! :woot: I'll :drunk: drink :cheers: to :proposetoast: that! :woot:
  20. Dec 24, 2014 at 3:08 PM
    #380
    AR15xAR10
    Welp, Doc told us to, so do it we must!!!!
    Merry Christmas!!!!!!!
