Oil catch can
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 25, 2014.
  1. Feb 28, 2014 at 2:20 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    That is correct. It a PITA to get everything bolted tight once the bracket is mounted. Take the bracket completely off of the can and mount the fender side first. Thread those nuts and washers on only 1-3 threads at first or you won't be able to mount the can. Then mount the lid of the can to the bracket fully. Then go back and do the fender nuts. You will see what I'm talking about when you go to do it
  2. Feb 28, 2014 at 2:29 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Yea I know what you mean. I think I'm going to try to make a small bracket that will bolt to those factory holes out of some 22 gauge sheet metal then bolt the can to it. Just so there aren't extra holes for now. I'll post back how it goes tomorrow.
  3. Feb 28, 2014 at 7:34 PM
    Silver PreRunner
    Silver PreRunner Well-Known Member
    Justin
    Buda, Texas
    07 PreRunner Tx Edition
    Aem Bruteforce "Cold"Air Intake, Aero Turbine, Satoshi Grillcraft, 3k Fogs, Led Halo Lights, Led Tail Lights, Oem Roof Rack, Camburg Spindles, All Pro Leaf kit with Timbrens, Rear Fox Shocks, Konig CounterSteers, Nittos 285s, Kenwood Single Din
    May be a dumb question I've been wanting to get one of these for my truck for awhile now but the only thing is I already have a good 130 almost 140 thousand miles on my 07. Would yall think its pointless for me to do it since I have a good number of miles, or the other answer which is do it pro long the life of my truck any way possible. Thanks TW :)
  4. Feb 28, 2014 at 8:04 PM
    Detective_Dan
    Colorado Springs
    I don't think it's pointless. It's cheap insurance IMO
  5. Mar 1, 2014 at 1:40 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Here's my small bracket I made. I'll redo it eventually cause its not as great as I want but it works for now. Installed at 1561 miles so the engine should stay clean most of its life.
    BassAckwards likes this.
  6. Mar 1, 2014 at 2:08 PM
    jro1
    jro1 Well-Known Member
    jesse
    Red Deer AB, Canada
    2011 Tacoma TRD sport
    Driver
    So is this how much oil is being removed from the engine after just 100 miles? I wonder how many people check their oil on a regular basis
  7. Mar 1, 2014 at 2:53 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Rookie/newby/idiot question, so why are these not installed from the factory? Simpy because of cost? If this will help keep sludge build up from the engine, how is this not a key part to the engine that Toyota installs? Are the effects debatable? Is it because in "theory" if you follow Toyota routine maintenance you shouldn't have to worry about sludge?
    I'm a little mad that I'm just finding out about these, would it do me any good to add one to my 185k engine, or if I have/had sludge build up, it's too late?
  8. Mar 1, 2014 at 3:03 PM
    jro1
    jesse
    Red Deer AB, Canada
    Driver
    It would prevent it from getting worse!
  9. Mar 1, 2014 at 3:13 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    What about the rest, why don't these come stock from Toyota?
  10. Mar 1, 2014 at 3:16 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    They aren't stock because burning it makes engine more emission friendly plus they can't count on every person taking the time to empty out safely.
    Brice likes this.
  11. Mar 1, 2014 at 3:21 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Ah, got to save the environment! Well if it is not too late, I think I know my next purchase.
  12. Mar 1, 2014 at 3:28 PM
    Detective_Dan
    Colorado Springs
    The only vehicle I know for a fact comes from factory with a can is the dodge viper acr.
    The truth is, most people would not check this on a regular basis, likely causing major issues if it becomes full and clogs the air intake and engine with crap oil
  13. Mar 1, 2014 at 3:34 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Which ill just be dumping it into used oil containers to recycle at local auto stores. I'll check mine in 100 also and see how things are doing.
    My one complaint about this can is the bracket they made, it rubs on the lower part and has already scratched it to hell but squeaks a ton.
  14. Mar 1, 2014 at 3:38 PM
    Detective_Dan
    Colorado Springs
    I carefully bent mine up so it does not rub anymore. It doesn't take much force to fix it
  15. Mar 1, 2014 at 3:40 PM
    #35
    jro1
    jesse
    Red Deer AB, Canada
    Driver
    Just ordered mine, thanks for the post!
  16. Mar 1, 2014 at 3:50 PM
    #36
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    OK..I understand the how and why of these...but what is the difference between the one that you got and did the write-up with vs. the one that has a filter on top of it ? For a different model that requires free flowing air as opposed to the vacuum that you said you had ?
  17. Mar 1, 2014 at 4:05 PM
    #37
    Detective_Dan
    Colorado Springs
    The filter on top is a breather. You can use that one if you wish, but you'll then need to cap the intake side of the pcv instead of running the intake hose back to it
  18. Mar 1, 2014 at 4:06 PM
    #38
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    Just bought one from Amazon, will show mounting location as I have a '13 4x4 6 speed
  19. Mar 1, 2014 at 4:08 PM
    #39
    F75gunslinger
    Christian
    Rochester,NY
    Gotcha...I'm good without the small filter..just wondered what purpose it served. One less filter to clean and inspect and the can still does the job ? Sweet !! Thanks !
  20. Mar 1, 2014 at 4:12 PM
    #40
    Detective_Dan
    Colorado Springs
    Yup. If you want to catch the maximum amount of oil, do what I did. Place some metal mesh from a chore boy scrubber in there. Don't stuff it packed tight, but just enough to give the oil mist something to condense to. It catches much more that way.
    Also DO NOT crank down the can tightly lmao. It's very hard to get off when it heats up and gets some vacuum pressure on it. Now imagine trying to remove it if you tightened it down hard haha
