Oil catch can
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 25, 2014.
  1. May 8, 2018 at 4:57 AM
    #601
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mine is necessary for the scope of my build. Drive and passenger valve covers both have AN fittings tapped into them. Then routing into the catch can. My catch can is not routed back into my intake, such as factory.
    flying_waitacoma and Soul Surfer like this.
  2. Aug 12, 2018 at 10:05 PM
    #602
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Looking to switch out my PCV valve to AN...does anyone what thread it is? @Torspd
  3. Aug 13, 2018 at 6:46 AM
    #603
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I want to say 3/8" NPT. It would have to be tapped. Unless you can find a metric to AN.
  4. Aug 13, 2018 at 9:32 AM
    #604
    SonnyBones
    Jeffery
    Ahh I see. What would the metric size be?
  5. Aug 13, 2018 at 11:09 AM
    #605
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'd have to pull it and measure, my man.
  6. Sep 14, 2018 at 11:49 AM
    #606
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
  7. Sep 14, 2018 at 12:32 PM
    #607
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  8. Sep 14, 2018 at 1:12 PM
    #608
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cheaper than my Draft42 Designs can. I like it.
    TacoCat likes this.
  9. Sep 14, 2018 at 7:13 PM
    #609
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
  10. Sep 14, 2018 at 8:21 PM
    #610
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
  11. Sep 15, 2018 at 4:00 AM
    #611
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is America mate. You're welcome to buy whatever your heart desires! Just remember, you get what you pay for .
    TacoCat likes this.
  12. Sep 15, 2018 at 4:05 AM
    #612
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  13. Sep 15, 2018 at 6:28 AM
    #613
    TacoCat
    Johnny-5
    Chantilly, VA
    Mine is a bit more. It brings coolant in from the radiator to heat the aos and prevent condensation. It also drains the oil back, so it never needs emptying. But like @Torspd said, buy what you wish.
    The W1 i bought for the taco was around a hundred bucks iirc, cheap when you figure in how much damage you could potentially prevent over time with sludge buildup. If you are FI, i have read that it is even more imoortant to run one.
  14. Sep 15, 2018 at 6:32 AM
    #614
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers:
    TacoCat[QUOTED] likes this.
  15. Sep 15, 2018 at 6:37 AM
    #615
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    That catch can sounds epic! One question though, I have read that the “oil” you catch should be discarded and not put back into the motor, since yours kills the moisture is this what allows the oil to drain back with no issue?
  16. Sep 15, 2018 at 6:42 AM
    #616
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If routed in line with the OEM hoses, one of the first problems to present its ugly head, is a vacuum leak. Associated with poor sealing of fittings or hose, with the cheap models. Followed shortly after by oil leaks.
    "Oil leak," is a little column A, a little column B though. As it means the unit is self draining, and requires you to change your oil more regularly. Lol
  17. Sep 15, 2018 at 6:43 AM
    #617
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Factory component on my '97 Bimmer. That oil coalesces and drains back. The heat from the system is what separates the moisture/air from the oil.
    TacoCat and Murphinator[QUOTED] like this.
  18. Sep 15, 2018 at 8:06 AM
    #618
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    If only our tacomas had a system like that!
  19. Sep 15, 2018 at 8:08 AM
    #619
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nothing that a little innovation couldn't overcome. I know of a few people in the S/C tips and tricks thread that could easily make it happen. ;)
  20. Sep 15, 2018 at 9:13 AM
    #620
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    No doubt! And for sure, the W1 I bought for $40 on fleabay is on the lower end of production quality. I was just curious what the added benefit was for 5x the cost.
