Oil catch can?
Discussion in '4th Gen. Tacomas (2024+)' started by mfalbojr, Apr 5, 2025.
  1. Apr 5, 2025 at 10:40 AM
    mfalbojr
    mfalbojr [OP] Well-Known Member
    Kansas City, MO
    2024 TRD Sport Silver
    Anybody install an oil catch can on the 4th gen yet? Not sure if I think it even needs one, the point of direct and port injection is to keep the intake system clean while also being efficient. Interested in what others think about this.
    shotgunbilly420 likes this.
  2. Apr 5, 2025 at 10:50 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I doubt if the exterminators are installing catch cans on their trucks. Are you putting more miles on your truck than an exterminator? If not you probably don't need an oil catch can. Maybe if your are upgrading the turbo you could benefit from a catch can.
  3. Apr 5, 2025 at 10:53 AM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    I’ve had one since January. It’s collected about 1/2 a cup of oil. Is it worth it? Thats 1/2 a cup of oil that didn’t contribute to gumming up the intercooler and lines. Also probably less carbon build up in the combustion chamber. I think it will have long term benefits but nothing noticeable short term.
    It’s an added layer of maintenance so checking it regularly is critical. When it was super cold -20 it would collect about 1/2 cup of water per tank of fuel! I’ve noticed the more the boost the more it collects ie towing.
    vprgts, mfalbojr[OP] and Rover31 like this.
  4. Apr 6, 2025 at 7:15 AM
    Toyturckman
    Toyturckman Active Member
    Dave
    2024 Tacoma Hybrid Limited Underground
    None
    Hey OP where did U get the catch can from?
  5. Apr 6, 2025 at 8:40 AM
    PDKTaco
    Montana
    2024 TRD Off-road
    snickers likes this.
  6. Apr 6, 2025 at 9:02 AM
    mfalbojr
    Kansas City, MO
    I bought mine off of Amazon. Not sure it is needed, but it can not hurt anything. There are many price levels available, I just bought 1 with good reviews.
  7. Apr 6, 2025 at 9:24 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Which one? Any modification needed
  8. Apr 6, 2025 at 9:28 AM
    roalddahl
    roalddahl Well-Known Member
    2025 DCLB OR Terra (pending), 2011 Access cab OR Silver
  9. Apr 6, 2025 at 9:32 AM
    Bishop84
    Bishop84 Well-Known Member
    Ya the benefits of a catch catch fall short if the lines freeze due to moisture content and cause a pressure buildup.
    You can insulate them but I wouldnt run a catch can up north unless you know what you're doing and check it weekly.
  10. Apr 6, 2025 at 9:42 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Not sure if I'm following this one... The unit is attached to PCV line (which is designed to vent gases from the crankcase back to the combustion chamber). So basically changing the design of the PCV and filtering oil, I assume. What has that do with the turbo...
  11. Apr 6, 2025 at 9:47 AM
    Bishop84
    It keeps carbon from recirculating into the engine, the throttle stays clean and ring lands stay clean. On turbos the pressure is higher so I imagine there is more gases to expel.
    It's a great idea on the old direct injection only models, but its not a huge deal on Toyotas with dual injector systems.
  12. Apr 6, 2025 at 10:05 AM
    Tacowrench
    Northern California
    I understand what you're saying :thumbsup:, but I'm a tad suspect. Sounds more like a gimmick. I remember the only vehicle, I owned, that was notorious for pushing oil through the PCV was my older 460 CID Ford V-8 (on my RV) and chocking the engine. I can't remember how many time I cleaned the system and replaced the valve. I finally had to disconnect the PCV to make it function better. Although not a turbo motor.
  13. Apr 6, 2025 at 10:35 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    I got the Burger one, would avoid it for now unless you dont mind doing some small modifications
  14. Apr 6, 2025 at 12:35 PM
    WyrmFoundry
    WyrmFoundry New Member
    2025 Red Tacoma TRD-OffRoad
    TBD
    My understanding of the T24A-FTS is that it has its own oil/air separater chamber (Looks serviceable ) built in before it reaches the PCV valve. Unlike some other engines that utilize an "L shape turn" in the valve cover on a Turboed engine which necessitates a catch can.
  15. Apr 7, 2025 at 12:48 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Hopefully it works. I still have flashbacks with my old BMW's crankcase ventilator valve. The CVV on the M54 engine has an oil separator built into it that's overly complex, sensitive to cold weather, and an unmitigated pile of crap.
    PDKTaco likes this.
