Oil change, 2024 trd off road
Discussion in '4th Gen. Tacomas (2024+)' started by 2023tacomer, Dec 8, 2024.
  1. Dec 9, 2024 at 10:36 AM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    Get yourself a oil pan mat.. keeps the oil from splashing all over the place
    JB_TN likes this.
  2. Dec 9, 2024 at 10:37 AM
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    I figured these were a thing and just haven't had chance to grab one.
    Vidman[QUOTED] likes this.
  3. Dec 9, 2024 at 10:57 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i use ramps maybe 50% of the time but the extra height of the old drop usually causes me more mess.. but honestly, i could just drive one side of the truck up on my sidewalk-curbs, and slide under it if i am feeling overly bloated.
  4. Dec 9, 2024 at 11:00 AM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    I have plastic ramps and 4wd helps, front wheel drive cars typically dont have issues.
  5. Dec 9, 2024 at 11:22 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    Yeah that thing doesn't drain oil. It hemorrhages the oil. It's like a full on food poisoning bowel venting spray.
    Light1984[QUOTED] likes this.
  6. Dec 9, 2024 at 11:25 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Many dealers will only do the free oil changes at the 10,000 and 20,000 miles.
    2024OffRoad likes this.
  7. Dec 9, 2024 at 2:39 PM
    miqie
    miqie Well-Known Member
    I use ramps, but only pull the truck half-way up. That gives me enough room to hold a bucket right uder the oil plug and avoid a mess.
  8. Dec 9, 2024 at 4:26 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    And that's one reason I added a Fumoto valve with the add-on hose.
    PDKTaco, Vidman and CrispyTacoLover like this.
  9. Dec 10, 2024 at 7:40 AM
    JC 4th Gen
    JC 4th Gen Well-Known Member
    Raleigh, NC
    2024 TRD Sport
    No ramps needed without a spoiler. If I did use ramps, I would use them on the BACK. That way, the oil draining from the filter does not land on the cross member.
    They added a nice flange to direct the oil from the filter pad, but it still tends to drip on the x-member. If they only extended that flange a teeny bit more...
    GrrrMaker likes this.
  10. Dec 10, 2024 at 7:43 AM
    JC 4th Gen
    Raleigh, NC
    2024 TRD Sport
    Yeah, I normally would not consider this, since the drain plug is so easy to access without skid plates, but that hot 0w-20 does tend to flow (and splash) like water!
  11. Dec 10, 2024 at 8:05 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    That's why I designed this and printed it off:
    It works well. If you know someone with a 3D printer, the file and instructions are here:
    https://www.thingiverse.com/thing:6742234
    Gmak621, DavesTaco68 and Light1984 like this.
  12. Dec 10, 2024 at 8:18 AM
    JC 4th Gen
    Raleigh, NC
    2024 TRD Sport
    Good solution! I was planning to rig something up for the next oil change. Although mine will probably include a cut up plastic jug and will look like a 3rd grader's science project. Or ramps on the rear of course. :)
    Oh, and that pic reminded me of those soft, rubber hoses used for the oil cooler. That seems like a future disaster to me. Anyone else concerned about that? I don't plan to do anything about it, but AN fittings and braided steel lines would look a LOT better there!
    EDIT - After looking at that pic again, I realized that the hoses are not carrying hot, pressurized oil, but coolant. So not a disaster waiting to happen - but I do question the efficiency of that oil cooler.
  13. Dec 10, 2024 at 10:29 AM
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    Would you please share the model/part# of the Fumoto you bought, or link even? Thanks in advance!
  14. Dec 10, 2024 at 10:35 AM
    Taco001
    Taco001 Well-Known Member
    24 OR
    I use a hydraulic jack right behind the driver side recovery hook and lift the truck about 4 to 5 inches. It makes getting under an back up again much easier. Im not overweight either.
  15. Dec 10, 2024 at 11:21 AM
    #35
    Sagebrush
    Gens 1, 2, 3, and 4
  16. Dec 10, 2024 at 7:41 PM
    #36
    GrrrMaker
    Woodstock, GA
  17. Dec 10, 2024 at 7:48 PM
    #37
    GrrrMaker
    Woodstock, GA
    All too true. Just talked to the service bay rep. this week about the "free" oil changes that came with my purchase. Every 10K mi. Also get two additional "free" oil changes. I asked the rep if I could do those on the intervening 5k marks and they said nope, the two extra "free" changes can only be applied after the 10K interval ones run out.
    Looks like I'm doing changes at 5k, 15k, 25K, etc.
    After the debacle I had with my F150 2.7L Ecoboost and it's turbos, It's going to be 5k miles oil changes for me.
    Gfenza89 likes this.
  18. Dec 11, 2024 at 8:12 AM
    #38
    Sagebrush
    Gens 1, 2, 3, and 4
    That one may stick out a bit. The one I installed tucks in nicely.
  19. Dec 11, 2024 at 10:17 AM
    #39
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    Nice guide so you don't make a mess. Unfortunately no 3d printer to make it.
  20. Dec 11, 2024 at 3:31 PM
    #40
    GrrrMaker
    Woodstock, GA
    if you use the Fumoto with the hose, no need for that. 3 feet of drain hose will easily reach your pan.
