Oil change - a quart low
Discussion in 'Technical Chat' started by PoweredBySoy, Apr 29, 2016.
  1. Apr 29, 2016 at 11:25 AM
    PoweredBySoy
    PoweredBySoy [OP] Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Just had my oil changed and the guy said it was a quart low. This is after ~4k miles, and the truck has 32k miles on it.
    Is this normal?
    I guess I'm only a little concerned because last week my friend was following me and he said he saw a small puff of white out of my exhaust. But maybe that's normal too. Could it just have been vapor?
    Thanks, motor heads.
  2. Apr 29, 2016 at 11:28 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Just keep your eyes on it. It wasn't empty and that's what counts.
  3. Apr 29, 2016 at 11:28 AM
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
    I know this might sound like a dumb question but have you checked for any leaks? And are you sure it was full correctly the last oil change?
  4. Apr 29, 2016 at 11:30 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    a quart in 4000 miles is excessive
  5. Apr 29, 2016 at 11:37 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I haven't, and I'm not. But I park in my garage, so I'm pretty sure it's not leaking.
    I'm going to be doing all my oil changes from here on out, I just didn't have time for this one.
  6. Apr 29, 2016 at 2:07 PM
    Medina33
    Erik
    Lax
    2010 dcsb 4x4
    Maybe the last they left a bit low and it have a bit since the last 4 months and yeah and make sure you start the car and let it sit for a bit and check the oil twice
  7. Apr 29, 2016 at 2:21 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    The last time I did mine (at 40k miles) I had this same thing. I was doing my own oil too. I think it was because I wasnt on enough of an incline, or that I didnt warm up the engine enough before. I have been keeping an eye on things, and I havent seen any issues yet. Ill be ready for another oil change in about 1500 miles, so we will see..
  8. May 1, 2016 at 7:35 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Come on we had time at the camp site to change it :p
  9. May 4, 2016 at 7:24 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Hah! I know. But I was so cold and tired by then all I wanted to do was crawl into my sleeping bag.
  10. May 4, 2016 at 7:54 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I would just keep track of the oil level for the next 5000 miles. Check the oil level with the engine cold and the truck parked on a level surface, and then check it again every 1000 miles under the same conditions.
  11. May 6, 2016 at 12:57 PM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I'm having trouble reading this dip stick. I drove for 10 minutes and checked it. But, I don't know, maybe I'm an idiot, but I can't see any distinguishable line for the oil level. I clean the stick off, go in and out, and then the entire lower half of the stick is smeared with oil. :tinfoilhat:
  12. May 7, 2016 at 8:25 AM
    nh_yota
    Jeff
    Portsmouth, NH
    Does your dipstick not have the two dimples near the bottom?
    I've found that best way to check the oil is to do it first thing in the morning or after the truck has been sitting (on a level surface) for a few hours. I just pull out the dipstick carefully and read it without cleaning it off and putting it back in, because as soon as you pull it out the firs time it will get oil along the dipstick tube and make it hard to read if you pull it out a second time.
  13. May 7, 2016 at 8:31 AM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    White
    White smoke is not burned oil. That's usually water or coolant.
  14. May 7, 2016 at 9:08 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Yeah, it does, but like I said, the oil is thicker down there, but then just gradually spreads up the stick, making it too hard to read where the 'level' is.
    I'll try your method. I thought you were supposed to check the oil when the engine was hot....
  15. May 7, 2016 at 9:15 AM
    nh_yota
    Jeff
    Portsmouth, NH
    You can check it hot or cold - it doesn't matter much as long as you give the engine a few minutes to let the oil settle when you shut it off.
    http://www.cartalk.com/content/when-are-you-supposed-check-your-oil-when
