Oil Change Alert- Public Service Announcement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 10, 2021.
  1. Oct 10, 2021 at 3:45 PM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    To be fair to everyone I must share something I JUST experienced for the FIRST TIME. I just returned from a 2,000 mile trip and when I was under the truck emptying the oil drain pan I was SHOCKED to find my Fumoto valve in the open position and the only thing preventing my oil from draining is a small black plastic cap that I put on the plastic nipple!!!!!!!
    I removed the black cap to find oil draining out and down my arm. I have been a longtime fanboy of Fumoto and this won’t stop me from sharing with all of you who provide countless useful information. Here’s what I know and think I know.
    1. I knew I didn’t install the locking device on the valve.
    2. I thought I properly closed the valve during last use.
    I’ve used these valves on ALL my vehicles for more than 10 years without incident. I also used the valve for years without the locking device installed. I can’t believe the valve was open and not draining out because I had the black plastic cap I use to prevent grime getting up into the valves nipple.
    My guess is I didn’t adequately close the valve during the last oil change. Although the valve should never open if properly closed I think the protective clip is a safety measure to ensure the valve is actually closed. You can’t install the protective clip if the valve isn’t fully closed.
    I hope this mistake I made helps someone from doing anything similar.
    MAD777, Biscuits, DAS Taco and 2 others like this.
  2. Oct 10, 2021 at 3:49 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I don't put no extra BS on my truck. The stock drain plug works just fine. Thanks for the warning
  3. Oct 10, 2021 at 3:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Any thing that can open by it's self I have no use for either. Just never could figure out the benefit.
    CusterFan, stu8319, DAS Taco and 8 others like this.
  4. Oct 10, 2021 at 3:54 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    that's the one reason holding me off from installing a fumoto. well, that, and the fact you could rip it off on a rock.
    Durango95, BMH, stu8319 and 5 others like this.
  5. Oct 10, 2021 at 3:57 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I mean that's why you shouldn't put that dumb valve on
  6. Oct 10, 2021 at 4:26 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’m a fan of the fumoto valve but just couldn’t get myself to buy one for this reason.
    CusterFan likes this.
  7. Oct 10, 2021 at 4:32 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Best I can tell after having been a working mechanic since 1978 is these valves might be for folks that have trouble using threaded fasteners and the concept of righty tighty and lefty loosey. another deal killer for some is having little or no feel for when bolts are getting tight. Just an observation, carry on.
  8. Oct 10, 2021 at 4:33 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Fumoto valves and the old spring clamp or new black clips are still going to go on all my vehicles. I've never had an issue with one opening inadvertently as the spring retainer keeps the valve lever depressed. I've run one on a lowered Supra for years now, arguably a tougher environment than the shielded Tacoma application.
    Everyone assumes some level of risk when performing maintenance on their vehicle. Just make sure barriers are in place to prevent things like this from happening.
  9. Oct 10, 2021 at 4:35 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I saw another thread mentioning this fumoto valve and then I googled it. Yeah, I didn't see a need to add something that is not flush with the drain pan. Will it fit with a skid plate on? If it protrudes, probably not.
    Ed
  10. Oct 10, 2021 at 4:44 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    They fit fine under skid plates. I've had one for 3 years.
  11. Oct 10, 2021 at 4:45 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I am not a fan. In my opinion, a valve like that is meant for something you need to open and close fairly often. I change my oil once, maybe twice a year, so the stock drain plug is perfect for me.
  12. Oct 10, 2021 at 5:57 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Forgetting to close the Fumoto valve all the way is no different than forgetting to tighten the drain plug all the way - it’s the OP’s fault (not trying to rub it in OP, just making a point to the people that are raggin’ on Fumotos that their product didn’t cause this issue). There’s no way a spring loaded valve is going to push itself up and past the lock and turn the valve to on by itself.
    Fumotos have their uses, and it’s a good design and a well-made product IMO. don’t really have a need for one on my Taco. But I have one on my 3rd gen 4Runner because I have aftermarket skids and there’s just a 3” hole to drain the oil thru. It was always messy as hell, oil always got all over the inside of the skid plate while I’d be trying to get my hand (and wrench) out of the way as quick as possible after taking the plug out thru that little hole... then it would never drain cleanly straight thru. So it was either live with the mess, or take the whole 50+ lb. skid off, which was a pain in the ass just to drain the oil. So I put a Fumoto on there with a 1’ plastic tube attached that will hang down thru the skid hole, and it drains nice and clean right into my oil catch bucket. When it’s done, I lock the valve closed, tuck the plastic tube back up into the skid hole and done. I would never go back to a regular plug on that truck.
  13. Oct 10, 2021 at 6:01 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    I agree. My fault, not Fumoto’s. Sharing my mistake so others won’t make the same one.
  14. Oct 10, 2021 at 6:03 PM
    clip
    VA
    15 OR
    OP has respect from me for mentioning they weren't sure if they'd closed it all the way and didn't use the secondary safety/retention measure offered by Fumoto, but that seems to have been overlooked by several replies.
  15. Oct 10, 2021 at 6:09 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'm a stickler for the old ways. Newfangled valves are too fancy for me
  16. Oct 10, 2021 at 6:21 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Stahlbus baybay. Lower profile and no external valve.
    tacoma_ca, oconnor and ClimbMaintain like this.
  17. Oct 11, 2021 at 5:01 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Past experience on one of my cars. Jiffy lube.. I was in a hurry and wanted an oil change before going on a trip so I stopped and had it done. When I got home to begin packing I noticed oil drops on my driveway. I figured maybe they were sloppy and crawled under to wipe up the oil from the pan…. Well it was sloppy but the hard plug was the problem.. the “professional” cross threaded it. Checked the oil level and took it back. They fixed it but I should have gotten a refund. Shows that even if you don’t do the work someone else can screw up.
  18. Oct 11, 2021 at 5:40 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    But then I have to remember where I stored the hose. :confused: :D
  19. Oct 11, 2021 at 6:23 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I own a Fumoto.
    I will not install it.
    Reason? If you don't have skid plates, it does protrude! (EDIT: ON A GEN 3)
    The worst part about changing oil on any of our last 5 vehicles is NOT the drain plug - it's the belly pans. Some have 8+ fasteners!
  20. Oct 11, 2021 at 6:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Had the valve on my truck for 12 years with no problems. Checking
    BOZOJUICE, usmc2msu and cryptolyme like this.
