Oil Change Alert- Public Service Announcement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 10, 2021.
  1. Oct 11, 2021 at 6:35 AM
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    But mods, upgrades, legos, :notsure:
    usmc2msu likes this.
  2. Oct 11, 2021 at 7:07 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    This type of oil drain device is best for small equipment applications such as mowers, pressure washers and such that have the drain on the side and can be easily flipped to drain it out.
    I would never install it on anything really expensive such as a vehicle, or at the bottom where it could be scrapped off or damaged.
    Just my $.02.
    shakerhood, DAS Taco and Junkhead like this.
  3. Oct 11, 2021 at 7:09 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have the safety clip on and a silicone nipple covering drain hole. I love my valve makes oil changes a breeze. No problems here
    Biscuits and usmc2msu like this.
  4. Oct 11, 2021 at 7:13 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
  5. Oct 11, 2021 at 7:15 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Right next to your filter wrench!
    Pablo8 likes this.
  6. Oct 11, 2021 at 7:17 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Public service announcement:
    If you put an easy open doo dad where there's not supposed to be an easy open doo dad, it is bound to open easily on its own.
  7. Oct 11, 2021 at 7:34 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I don’t understand why would you want a valve that may open or get damaged while off-roading . Is it that hard to remove a bolt ?
    cryptolyme likes this.
  8. Oct 11, 2021 at 8:00 AM
    YellowSnow
    San Diego
    19 TRDOR
    because humans are simps, and we will buy shit for the sake of buying shit because we think we need it.
  9. Oct 11, 2021 at 8:18 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I used one on My previous vehicle, Jeep Liberty CRD because of the way the stock oil plug was a hex keyed bolt with few threads the could be easily damaged if over tightened or the washer/gasket not used. it would also damage the cast aluminum oil pans threads. It was a very common thing for that uncommon engine. in 12 years of owning it I never had any issue with it leaking or opening. I had the shortest one and it was above the skid plate so never had any issues off road either. I never used the plastic clip most of that time as it didn't exist early on.
    Would I put one on my Tacoma now? I'm really on the fence about that. The Tacoma has a steel oil pan that is not so easy to damage like the jeeps was and in a location not hard to reach so I don't see lots of benefits to it like before. I do believe Fumoto valve is a good well made product. You can't blame the product for user error.
  10. Oct 11, 2021 at 8:48 AM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Have had a Fumoto valve for the last 3.5 years with zero problems because I never installed it.
  11. Oct 11, 2021 at 8:50 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Winning
    Junkhead likes this.
  12. Oct 11, 2021 at 8:50 AM
    GBR
    GBR Well-Known Member
    19 TRD OR
    I put one on mine. I got tired of the 0-20W oil splattering everywhere, otherwise I wouldn't have bothered. I put the clip on it after closing the valve and feel pretty damn confident the valve won't be damaged or open on its own.
    Now I don't get pissed about oil getting everywhere after a drain. If that makes me a dumbass that can't handle a drain plug, so be it.
  13. Oct 11, 2021 at 11:30 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Im thankful that those of you that don't know how to ensure a ball valve is shut, then confirm it's shut, then use a secondary securing device refuse to use one on your vehicle. This ensures that the oil will stay in your crankcase until you decide it's time to drain it.
    May I suggest you also implement a lockout/tagout program when you work on your truck too?
    :D
    I joke, but I have tagged out my ignition when I've got things like a loosened crank bolt that would cause catastrophic damage if not attended to.
  14. Oct 11, 2021 at 11:45 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Never saw the allure of those myself.
  15. Oct 11, 2021 at 11:47 AM
    #35
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Soooo, you neglect to use the locking device and the valve opened, even though you closed it?
    Without the locking device.
    The locking device, that makes sure the valve does not accidently open.
    The LOCKING DEVICE.
    Just checking.
    Totally the manufacturers fault.
    Radelix likes this.
  16. Oct 11, 2021 at 11:57 AM
    #36
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    make a check list #1 is fumoto valve closed.
    Taco_mike73 and clip[QUOTED] like this.
  17. Oct 11, 2021 at 12:34 PM
    #37
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Well... where is that?
  18. Oct 11, 2021 at 12:53 PM
    #38
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    There is a reason that there is screw on plug, I upgraded mine to Goldplug to catch any micro metal stuff...no valve for me!
  19. Oct 11, 2021 at 12:55 PM
    #39
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    For the record, the Fumoto valve is installed by screwing it on.
  20. Oct 11, 2021 at 1:12 PM
    #40
    DAS Taco
    DAS
    2017 TRD Offroad
    It's a plug with an easy to undo valve at the end, if it flips open then it is the end.
