Oil Change Alert- Public Service Announcement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 10, 2021.
  1. Oct 11, 2021 at 1:19 PM
    #41
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Well, not actually. I started this thread BECAUSE the valve WAS open. Guess what? Its not the end?
    Skydvrr and clip like this.
  2. Oct 12, 2021 at 5:14 AM
    #42
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Totally Man you have to check your work. I forgot the close the Valve on my Liberty CRD once that had one of these on it. Nothing really bad happened. I still had my drain pan under the engine and started to pour the new oil in. I had about a quart or two in when I heard it draining out the bottom into the drain pan. My fault I was rushing and not paying close enough attention to my work. Good thing is I caught my mistake in time so only some oil got wasted, nothing else.
    Skydvrr, CrufflerJJ and clip like this.
  3. Oct 12, 2021 at 6:48 AM
    #43
    mquibble
    Michael
    2021 TacomaTRD Pro
    I know I closed the valve but I’m now sure that I didn’t close it properly. Even without the protective clip the valve is very unlikely to open. I must have closed it just short of the lever popping into recess that prevents the valve from turning.
    I’m just now realizing those who don’t have a Fumoto is probably unaware of how the valve works. It is not a regular ball valve that you can turn left or right without restriction. Once the valve is closed properly the lever retracts and sits into a recessed pocket that prevents the lever from moving left or right. In order to move the lever one must push the lever forward before you can move it laterally.
  4. Oct 12, 2021 at 6:57 AM
    #44
    Taco_mike73
    York, PA
    yep you are 100% correct. it does have that safety bit built in.. I didn't know about the dust cap being a option. When I first got to use one it was a spring clip that you had to put over it with pliers if you wanted extra insurance it couldn't be opened easily. then at some point the plastic clip thing came out that was much easier to work with. I lost the metal spring clip in my stone driveway... I did not like it.
    clip likes this.
  5. Oct 12, 2021 at 7:25 AM
    #45
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    The black plastic clip is definitely easier than the spring clip, but I'm positive that spring clip won't come off by itself. Still, I use whichever ships with the valve at the time since both are a good design.
    Otto Mation likes this.
  6. Oct 12, 2021 at 7:32 AM
    #46
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    What about beer? How cool would that be to look at the can and it opens right up on command. :thumbsup:
    Sharpish, Skydvrr and Taco_mike73 like this.
  7. Oct 12, 2021 at 7:47 AM
    #47
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    The Fumoto works extremely well and will never open by itself and drain your oil unexpectedly...as long as you are at least 3% smarter than the valve.
    Which explains much of the hate exhibited towards it.
  8. Oct 12, 2021 at 8:02 AM
    #48
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    My brand new Fumoto (never used) is going on the TW Marketplace soon…
    No issues, I just never got around to installing it.
    Gen2 Man likes this.
  9. Oct 12, 2021 at 8:12 AM
    #49
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I remember once ... Because I was no longer there to do the actual work myself ... My ex called me one day to ask where she should get the oil/filter changed on her car. Of course I said 'Oh, just go to Jiffy Lube. They do a great job and you'll be in-n-out of there in no time'..:devil:
    I never heard back, but after that she never asked for my 'advice' again.
    Mission Accomplished.
    tacoma_ca and Gen2 Man like this.
  10. Oct 12, 2021 at 9:17 AM
    #50
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    That happened to me one time back in the 1990's. I use the dealership service dept. now but I check my oil before I pull off the lot and when I get home I slide under the truck and wipe the oil off the tech slopped on the under side of my truck. Gives me a chance to see if any oil is leaking out.
  11. Oct 12, 2021 at 12:46 PM
    #51
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I'll make the call when I do my first oil change. My next scheduled maintenance at Dealership is 10K miles in Feb 2022.
    At/about 15K miles, I'll go on Dover AFB and change the oil at the Auto Hobby shop...see what all the fuss is about.
    Ed
  12. Oct 12, 2021 at 1:34 PM
    #52
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Wow... sounds like they're not fool proof. Thanks for sharing... good information and a great reason not to ever install one of those things.
  13. Oct 18, 2021 at 8:36 PM
    #53
    OffroadToy
    You know, if that plastic cap hadn't been on and you drove the truck there's a good chance you'd be looking at getting a new motor. I've been doing my own oil changes for the last 50 years and I've never had a problem with oem drain plugs... just saying.
    Gen2 Man, shakerhood and Skydvrr like this.
  14. Oct 18, 2021 at 8:45 PM
    #54
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Dang that's crazy. I've probably been changing my own oil for 15 years and I've ran into all kinds of issues. Random leaks, stripped threads (from previous owners), tons of mess etc.
    usmc2msu likes this.
  15. Oct 18, 2021 at 8:54 PM
    #55
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Meclizine and shakerhood like this.
  16. Oct 19, 2021 at 3:49 AM
    #56
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Idiot-proof it: Drill a little hole in the lever and safety wire it closed. Drill the same size hole under the top edge of your funnel. When you cut the safety wire thread it through the hole in the funnel to remind you to close the valve and re-wire it safely closed before filling with oil. My Fumoto is sitting on the workbench, along with my Baxter spin-on adapter. Another ~1500 miles and they will both go on.
  17. Oct 27, 2021 at 11:00 AM
    #57
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    You seem to like over complicated solutions or maybe a solution to a problem which does not exist. Is this a great country or what. Go get em tiger
    SR-71A likes this.
  18. Oct 27, 2021 at 11:04 AM
    #58
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    WOOOOW. Speechless.
  19. Oct 27, 2021 at 11:15 AM
    #59
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    What spin-on filter will you be using? How do you know its bypass valve pressure is appropriate for the 3.5L? :devil:
  20. Oct 27, 2021 at 1:34 PM
    #60
    mquibble
    Michael
    2021 TacomaTRD Pro
    I’m using one of these… Amsoil EA15K51 or NAPA PFL 41393. I’m not concerned about the bypass valve pressure because I think it only comes into play if the filter were to get too clogged and thereby starving the engine of oil. With my oil regimen and frequency I don’t believe that will be a risk. If I have the bypass valve purpose incorrect I’m most certainly receptive to be educated here. Thanks in advance for any help.
