Oil change and extras?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thatdood, Nov 29, 2012.
  1. Nov 29, 2012 at 6:23 AM
    thatdood
    thatdood [OP] Well-Known Member
    Texas
    Black 09 DblCab SR5 minus mud flaps
    When I take my truck to the dealership (yes I know, stealership.. but it is actually fairly cheap) to get an oil change they try to get me to have the rear end flushed and all this other stuff - total cost of about $600. I've talked to several people that have never had that done and their trucks run fine for several hundred thousand miles. What do you guys think?
  2. Nov 29, 2012 at 6:36 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I think if you plan to keep the truck for a long time, just follow the maintenance schedule in your manual and you'll be fine.
  3. Nov 29, 2012 at 7:38 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Changing the rear diff fluid is simple, you can buy the "Best" syn oil available and do it in less then 30 min for less then $40 or so
  4. Nov 29, 2012 at 8:06 AM
    thatdood
    Texas
