Oil Change Between 5k ToyotaCare Service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H4630, Nov 10, 2013.
  1. Nov 10, 2013 at 8:42 AM
    H4630
    H4630 [OP] New Member
    '13 Accesscab TRD Offroad
    Stock so far...
    Hello,
    I recently purchased a new 2013 Tacoma with the 4.0L V-6. It currently has a little over 1,000 miles on it. The ToyotaCare maintenance plan won't cover an oil change until 5k miles which makes me a little uneasy. Should I change the oil myself right now and let the dealer do it again at 5k? If so, what brand of oil should I use to best match what the dealer will use at 5k miles?
    -Thanks
  2. Nov 10, 2013 at 8:47 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    If you want to waste time, money and effort then change it. There is no reason to change it early anymore. Enjor your truck.
    Check out bobistheoilguy.
  3. Nov 10, 2013 at 8:48 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You can if it makes you feel better, but it will be fine if you don't. Go get oil and filter from the dealership if you want what they use. A lot of guys use mobil-1.
  4. Nov 10, 2013 at 8:50 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    The Toyota care maintenance changed mine with 1800 miles on the odometer. (I don't drive very far)
    Your manual says 5k or 6 months, what ever comes first. Toyota care says the same thing.
  5. Nov 10, 2013 at 9:20 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I changed mine out at around 1,000 miles... not sure if that was the best idea though after reading (not sure how true this is) that Toyota fills them up with some special "break-in" oil at the factory.
  6. Nov 10, 2013 at 9:31 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I'd change it early just because its what i've always done. It is really satisfying when you change it and see for yourself that the oil is clean and free of metal shavings. No matter what anyone else says, i'll always change the first oil between 800-2500 miles.
  7. Nov 10, 2013 at 9:32 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd change the rear diff oil at 5k. You won't believe the shit that comes out.
  8. Nov 10, 2013 at 9:34 AM
    AR15xAR10
    Oh shit...i'm at 33,400 and my diffs, t case, and tranny haven't been serviced yet. Now i'm worried :eek: :/
  9. Nov 10, 2013 at 9:37 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ You should be.
  10. Nov 10, 2013 at 9:54 AM
    bassinman
    bassinman Well-Known Member
    Gilbert Arizona
    11 Prerunner SR5
    Tint, WeatherTech mats, Differential Breather Mod, Fogs on anytime mod, Seatbelt chime disabled, glove box led's, Rear spring TSB
    I don't think Toyota is concerned about months or miles. You get 5 service coupons under the free service program. I used all 5 of mine changing oil every 6 months. I put very few miles on my 2011 (most spent towing a bass boat), so I am concerned more about condensation than I am about oil breakdown. Dealer never questioned frequency of service appointments. By the way, my 2011 now has a grand total of 9753 miles on the odometer.
  11. Nov 10, 2013 at 1:36 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I tried Toyota service with my last truck 2 times and both times they didn't do what they were supposed to do. Took it in the first time and they didn't rotate the tires (I marked them with chalk). Took it in the second time and they didn't rotate the tires again (again marked with chalk). It stated very clearly that they would and I even asked the manager over the express service if they did. He said yes and then I took him out and showed him that I had marked 2 tires with distinctive marks and they in fact were not rotated. After that I said screw the "free" maintenance and did it myself from that point forward. They won't touch this new truck unless something goes wrong with it. At least when I do the maintenance I know it is done correctly.
