Oil Change by miles or months?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Shape, May 6, 2013.
  1. May 6, 2013 at 9:35 AM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    Since I tend to put low miles on my truck I am always torn on which to stick to. At the moment I am at about 6 months since last change, however I have put a whopping 2300 miles on the truck in that time with Mobil One full synthetic and Mobile One filter.
  2. May 6, 2013 at 9:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If I didn't put enough miles on in a year, I'd change it. Otherwise, I'd stick to 5k mile intervals. That's just my opinion, I'm not a mechanic, that's just what I'd do.
  3. May 6, 2013 at 9:41 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I am sure you will get all kinds of opinions but if it was me, I would stick with the 5000 mile change or annual if you dont get to that milestone.
  4. May 6, 2013 at 9:45 AM
    WThomas1250
    WThomas1250 Well-Known Member
    I was just wondering about this today. My family's extra vehicle is an old Wrangler. It gets very low miles put on it (Mostly cause of the rough-ass ride, go figure). But it makes me feel weird knowing that the oil in it is over 9 months old, especially in an 18-year old vehicle. It leaks some oil, and since its low I figure I'll go ahead and change it instead of just adding some.
  5. May 6, 2013 at 9:47 AM
    The Shape
    Forrest City, AR
    Yeah I was leaning towards waiting till the 5K mark. I hate the idea that I would possibly be draining perfectly good and expensive synthetic oil.
  6. May 6, 2013 at 9:56 AM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    I put low Km's on my truck, I change once in the spring and once in the fall. I also use oil stabilizer. Even if I am draining "good" oil, I am also protecting my investment and it's still cheaper than if I drove it regularly. Just my 2 cents
  7. May 6, 2013 at 11:53 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I believe in my manual it states every 6 months or 5k miles; which ever comes first.
    I have Toyota care for the next two years. Free oil changes for me, so I will be going every 6 months. I will be lucky to put 4K on mine in a year.
  8. May 6, 2013 at 11:58 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    It depends on the car. If the oil looks clean at 5k, I might push it another few thousand miles. I think I had almost 10k (99% hwy miles) on my Mazda 3 before I changed it....and it still looked new. I'll probably change my oil in the Tacoma around 5k, maybe more if it looks especially clean at that time.
    I've read that newer cars can probably go much longer between oil changes than what most recommendations state. I say look at the oil and keep in mind your driving style. If everything "seems" good, then give it another 2-3k miles.
  9. May 6, 2013 at 12:04 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I go by 5k interval unless I don't make the 5k but I know I rode hard ... I will still change it just cause of the possible engine strain..
  10. May 6, 2013 at 12:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I'd wait a year with synthetic.
  11. May 6, 2013 at 12:19 PM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    My 03 Camry with 25K on it was changed once a year until my daughter started driving it 4 months ago. It was doing fine. You will be good with synthetic and once a year or 5K whichever comes first.
  12. May 6, 2013 at 1:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I agree.
    Also, I drive 10k miles per year so the 5k miles or 6 months requirement works just right. I use regular petroleum motor oil 5w30, whatever meets the specs and is on sale... NAPA, Castrol, Chevron, Peak, etc. If my mileage were different, I'd still follow the "5k/6mos whichever comes first" requirement.
  13. May 6, 2013 at 1:18 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    ^^^This. I'd wait 6 months for dino but wait a full year with synthetic.
  14. May 6, 2013 at 4:50 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) With 12 AC , the oil changes are free, and I only had 4500 miles in 6 months. My 12month oil change was at 8400 miles . I have sent oil samples to Blackstone labs and the results are getting better.If we had not taken some trips, I still would not have gotten over 5000.
    I will still keep the 6 month interval after the free oil changes are done. The price is not that much, the oil is 6 dollars a qt. at the dealer and the filters are only 4 bucks. I find it to be a good investment.
  15. May 6, 2013 at 6:22 PM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    Did my 1yr/10K service today at the dealer with 7300 on the clock. I was one week past the 1 year mark of ownership.
    If I was paying I definitely would have stretched it to closer to 10K.
  16. May 6, 2013 at 6:33 PM
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    IMHO 6mo or 5k.
    I run 0w20 in my DD 2010xb and change it out every 5k or 75days...golden brown but I rather not take chances. I put about 3500 miles every 6mo on my Taco still service it at the time interval...
  17. May 6, 2013 at 8:22 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Exactly what I would do.
    I put approx. 8K miles per year on my truck. I write the date I changed oil & filter on the oil filter with a silver sharpie.
  18. May 6, 2013 at 8:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You cannot judge the oil by how it " looks ". Oil gets dark due to it performing the job it was designed to do: Suspend contaminates and combustion by products. Just because it is dark doesn't mean much.
    That being said I would go by the 5K or 6 months whichever is first.
